high oil pressure
Old Jul 9, 2012 | 05:10 PM
supraturboman's Avatar
supraturboman
Default high oil pressure
Ok, today I changed the oil on my 03 with 28k on it. I have been using Kendal full synthetic with a wix oil filter. But today I switched to Mobil one. Upon start up it was at 60 psi, no alarm there. But when driving it goes up to 120 psi. NOT NORMAL!.
Anyone else have this issue?
Sorry for bad punctuation as I am on my phone.
Old Jul 9, 2012 | 05:27 PM
Italianjoe1's Avatar
Italianjoe1
Same once it warms up? It will do that cold for sure.
What weight of oil on the old and new?
Old Jul 9, 2012 | 05:44 PM
supraturboman
I am using 5w30. And it does it when it is completely warmed up. The highest it used to get up to was 60 while driving and go down to less than 20 at idle warmed up.
Old Jul 9, 2012 | 05:45 PM
e30cabrio's Avatar
e30cabrio
After my stroker was done I had crazy high pressure. I installed an aftermarket gauge and found teh oem gauge was 20lbs high.
I'd have mechanic put a gauge on your car if I were you to see if that is the issue.
Old Jul 9, 2012 | 05:51 PM
supraturboman
Actually I did check with a mechanical guage, and it came back with the same results.60 at idle and 120 at driving once warmed up.
Old Jul 9, 2012 | 08:05 PM
ronn1's Avatar
ronn1
Since you used mechanical gauge...this is for real and not the pressure sensor or gauge. Wonder if the filter is messed up..since it's certainly not the oil and it was FINE before the change. Don't really see how the filter would effect pressure that much, but it's worth a try. I would replace the filter again. You don't want to run excessive pressures.
Old Jul 9, 2012 | 08:49 PM
Italianjoe1
I've run mobil 1 and never seen that type of sudden change, and my car has seen a variety of oils. Even with a much thicker oil the pressure still dropped down once it warms up.
Maybe you got a weird batch of oil? Change it again and see what happens would be my first thought.
As mentioned above, suggest a filter change only first to rule it out.
Old Jul 10, 2012 | 04:52 AM
cubs4worldseris's Avatar
cubs4worldseris
I've been using mobil 1 full synthetic 5w-30 and a mobil 1 filter on my car ever since I purchased the vehicle. Oil pressure is high on cold start, low on warm idle, higher on acceleration, lower again on idle. Never had any problems.
Like the aforementioned, I would just change out the oil and the filter, not much of a sunk cost to do an oil change.
Old Jul 10, 2012 | 07:39 AM
tylerxfire's Avatar
tylerxfire
its ur oil pressure sensor also known as oil sending unit..get a new one and replace it..easy fix...
use the search button instead of making a new thread..this topic has been covered soooooooooooo many times on here
Old Jul 10, 2012 | 10:28 AM
supraturboman
It was checked with a mechanical gauge and it read the same as the guage in the car. So it is not the oil pressure sender. I changed the filter to a Mobil 1 filter now and it reads the same. I will switch back to the oil I used before.
Old Jul 10, 2012 | 10:31 AM
tylerxfire's Avatar
tylerxfire
oook...so how does that say its not the oil sending unit?..im 99% sure it is your sending unit..
Old Jul 10, 2012 | 10:40 AM
supraturboman
Because I used the gauge and screwed it into the block where the sending unit goes to , that's how i know. It is reading the pressure from the block not the sending unit.
Old Jul 10, 2012 | 03:37 PM
ronn1's Avatar
ronn1
It's amazing that people don't *get* what your saying here
The sending (*sensor*) unit is attatched near the filter and can be defective. Yours isn't...as you pointed out, since the mechanical hook up matched the sensor ..which inputs the gauge. Are you going to change the filter? Might want to do that, since it's a simple task. Theoretically...It's hard to see how that would cause the problem..but may as well give it a shot.
Old Jul 10, 2012 | 06:11 PM
supraturboman
I did change the filter and top off the oil. Same results, extremely high pressure. So I drained the oil and put Kendal full synthetic oil in and now it's fine. I don't understand it. How can the oil make the oil pressure jump up so much .
Old Jul 10, 2012 | 06:26 PM
e30cabrio's Avatar
e30cabrio
Mislabeled weight maybe?
Old Jul 10, 2012 | 06:50 PM
J.$'s Avatar
J.$
I'm glad you figured that one out. Out of curiosity though, oil pressure was at 120PSI when cruising? Say, about 2500-3000RPMS?
It could've been mislabled oil but I can't imagine it would cause your pressure to jump up that high. I run Mobil 5W30 but at cruising speeds it's no where above 60PSI.
Old Jul 10, 2012 | 06:55 PM
supraturboman
Yes normal driving it was pegged at 120 psi. At idle it was 60 psi. Very very odd
Old Jul 11, 2012 | 11:45 AM
ronn1's Avatar
ronn1
Damn...that's just weird. Even if you used 20/50..I doubt PSI would reach 120 in normal driving/60 idle..no way. I think when you drained oil the second time...something *let go* which may have been stuck. There is an oil pressure relief valve behind the filter..maybe that was stuck?
Here's a pic:
Has ball bearing which could stick:
It's #5 in this drawing:
Old Jul 11, 2012 | 04:23 PM
Italianjoe1
I ran 15-50 castrol for one oil change interval and it still had a hot idle under 30psi. Something definately got stuck or blocked. Glad it's back to normal.
apex locator
Jul 23, 2021 02:27 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
