04 350Z Tach and A/C both dead
My car is a Touring Conv, the car has some issues, the A/c compressor, tach and the tranny started acting up all at the same time. The tach and cold air all went dead, the tranny bangs real hard into second gear and wont dont shift (automatic) any one have any ideas. Have had the car for 2 weeks....
anyone have a servive manual online maybe a fuse??
Ok not a fuse today drove again fine at start up
With in 5 to 7 minutes Tach goes dead, ac comp
Goes off blows hot air then Tranny starts banging
Really hard into each gear. So I'm gonna try and
See if I turn car off than back on if it fixes it because
I did stop at store and when I restarted every thing
Was working again so I tried it at a red light, the car
Acted like it wasn't getting any spark, just ran over
So now I have my 4 way flashers going finally kept
Cycling the key and it started, every thing working
Again for about a minute than same thing.
Please help!!!!!
Please help!!!!!
I suspected a loose ground also, but the old owner added about 3 extra grounds on the engine block to frame. It has been running fine for last three days. But the TCS off light is always on a Slip light both those never go out.
I put on code reader have a P0345 and a P0462 could the camshaft sensor put the car in safe mode??
I just replaced the Drivers side (curved) Bank2 Camshaft sensor, very easy to replace. reach behind engine from passenger side and take 10mm bolt out, squeeze clip and plug poped off. Replacenwith new while having the battery terminal off the whole time, reconnect cable and run's great.
Now to the gauges flashing on and off theres a white plug with a blue relay down by the battery has orange wires about 4 wires. The battery was not secured down and smashed the plug. Not every thing works great so if your speedo or tach jumps up and down or dies for no reason check this plug
liqalu04
Jan 2, 2022 12:58 PM
