Hard to shift into 2nd, but dealership says no issue
Old Aug 7, 2012 | 01:04 PM
Rex08Z's Avatar
Rex08Z
Default Hard to shift into 2nd, but dealership says no issue
I know there have been some topics on this, but I care a lot about my car and what happens to it, so I started my own thread. The title says it in a nutshell, basically. Driving off, it's always very tough to shift from 1st to 2nd. I had Nissan's service department look at it today. They say my car has no problems at all, including the transmission and clutch.
Is that how it's going to end...stuck with a stubborn 2nd gear for life? Please help me, My350z.com! I have a 2008 Enthusiast Coupe with 6MT and 47k miles. FYI, I bought my car 2 months ago from another dealership.
Old Aug 7, 2012 | 01:09 PM
mr. sparco's Avatar
mr. sparco
You didn't notice it during the test drive?
Old Aug 7, 2012 | 01:11 PM
mjc1055's Avatar
mjc1055
if you're convinced there's a problem and this dealership won't help you out, take it to a different one.
Old Aug 7, 2012 | 01:17 PM
Rex08Z's Avatar
Rex08Z
When I bought it, I had test drove a handful of newer sports cars, and none of them shifted as smoothly as my '92 240sx for instance, so I told myself I'd get used to it. When I got used to the other gears, I noticed 2nd gear was sort of not letting the shifter in unless I pull hard on it. Third's fine, fourth's fine, etc. I brought it to Nissan because I thought the previous owner beat on it and I'd need a new tranny and/or clutch.
I went especially to these guys because I heard good things about their service dept.
Old Aug 7, 2012 | 01:22 PM
05UltraYellow's Avatar
05UltraYellow
sounds like a synchro. any grind noise into gear or just resistance?
Old Aug 7, 2012 | 01:29 PM
Bret86944's Avatar
Bret86944
My car does that too. I literally have to double clutch second gear until the transmission warms up. I have zero other problems though. And once it warms up it's smooth as butter. Really weird.
Rex08Z's Avatar
Rex08Z
No grinding thankfully, but I get a clunk noise when 2nd gear catches.
Old Aug 7, 2012 | 02:54 PM
starvinmrvn's Avatar
starvinmrvn
I have a '06 bought new and has had a difficult 2nd gear since new. 50k miles now and no serious problems as a result *yet*. I also brought my car in for its first check up and raised the question and the mechanic said they all do it...I just shrugged it off.
Old Aug 7, 2012 | 03:02 PM
Rex08Z's Avatar
Rex08Z
Well even if it's normal, that doesn't make it favorable. Would changing the transmission fluid or clutch help at all?
Old Aug 7, 2012 | 03:14 PM
05UltraYellow
couldnt hurt... mine is super noisy and my Z buddies and i have chalked it up to bad synchros... time to save for last revision of the tranny...
what part of NY are you in? big nissan/infiniti meet in danbury right outside of NY
september 8th..
Old Aug 7, 2012 | 03:34 PM
Rex08Z's Avatar
Rex08Z
september 8th..
Suffolk County. I'll look into it, thanks.
Old Aug 7, 2012 | 06:08 PM
terrasmak's Avatar
Pull hard NO, slow and smooth YES. Transmissions make for higher HP can not be slammed into gear like the typical honda trans.
Old Aug 7, 2012 | 09:10 PM
Rex08Z's Avatar
Rex08Z
I know how to shift. I'm only having trouble with one gear.
@05UltraYellow, you say the later revision of the transmission? I have the latest 350z, what else was there? You mean the 370Z tranny?
Old Aug 8, 2012 | 12:17 AM
Szam121's Avatar
Szam121
They way i see it is u have a couple options.
Take it to another dealership(I'm assuming you have a warranty)
Take it to a reputable shop specializing specifically in transmissions see how they feel about the transition
Change the fluid sometimes this works miracles for awhile
My Z has 46k and its just matter of just about a flick of the wrist. Unfortunately it could be alot of things but synchros is kinda what I'm thinking.
Old Aug 8, 2012 | 05:58 AM
Rex08Z's Avatar
Rex08Z
It drove fine from the dealer, but I don't even know what they did to inspect the tranny. I think I need to drive it more to really decide if it's a high priority problem or not. I'm starting to believe what Z owners say about that it's easier to shift after letting the transmission warm up.
Old Aug 8, 2012 | 06:18 AM
starvinmrvn
Agreed...I have missed shifts into 2nd gear as a result...but I prefer to pretend like there isnt a problem and go on about my day..lol I am changing Tranny/diff fluid soon and if I have any difference I will report back.
Good luck to the OP on a solution.
Old Aug 8, 2012 | 06:41 AM
Bret86944's Avatar
Bret86944
Try double clutching. I guarantee it will go right into gear. I have no explanation for why though.
Old Aug 8, 2012 | 06:54 AM
Rex08Z's Avatar
Rex08Z
I have no problems downshifting to 2nd. It's shifting up where I really notice it. I use heel toe btw.
Old Aug 19, 2012 | 12:44 PM
pbn85's Avatar
pbn85
Which Nissan dealership if I may ask? The HR transmissions are pretty solid for the most part. They are also very notchy. It could just be notchiness you're noticing.
Old Aug 19, 2012 | 12:50 PM
Rex08Z's Avatar
Rex08Z
From what I'm hearing, all the trannies are more or less like this with a rough 1-2 shift. I adjusted my clutch closer to the floor(engagement point was bothering me) and the shifting is much easier now.
Oh and the dealership was Smithtown Nissan.
apex locator
Jul 23, 2021 02:27 AM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
Cashwin
Oct 1, 2015 06:36 AM
