My Valve Stem Broke... Should this be a Warranty Item?
Old Jan 9, 2004 | 10:59 AM
Static's Avatar
Static
Default My Valve Stem Broke... Should this be a Warranty Item?
I was unscrewing the cap on my rear right valvestem.. and basically the top half of the valve stem came of with it! Its not entirely busted... just the top half of the part where u can put the cap on.. but now I can barely put air into the valvestem.. and I can't seem to understand how this could have broken just like that! My rim has not been damaged at all... The dealer doesn't wnat to warranty this item.. shouldn't this be a warranty issue????
Old Jan 10, 2004 | 09:40 AM
themyst's Avatar
themyst
probably not. if you bent a part of your suspension, thats your fault, not a defect... same goes for a valve stem. it should be a cheap fix regardless, I wouldn't worry about it.
Old Jan 11, 2004 | 03:53 PM
Static's Avatar
Static
Well actually, a new valve stem costs over 300 dollars because I have the touring edition with the tire pressure guages. Bending my suspension would be due to an accident or my negligence... this thing just plain out broke... all I did was attempt to take off my valve stem cap..
Old Jan 11, 2004 | 05:26 PM
zand02max's Avatar
zand02max
Do you have the tire warranty? If not, I think your're out of luck!
Old Jan 11, 2004 | 10:27 PM
350ed's Avatar
350ed
Professional
Isn't the valve stem separate from the TPS? I know people remove the TPS and sell 'em.
Old Jan 12, 2004 | 08:47 AM
WashUJon's Avatar
WashUJon
It should be warrantied with the TPS monitor, since its all one unit. I'd definitely bring it up with your dealer. They'll have to replace it.
I was under the impression that those people who sell them have gotten new tires and rims with completely new valve stems in them anyway.
Old Jan 13, 2004 | 07:08 AM
350ed's Avatar
350ed
Professional
Right, but some people strap mount them on the rims and I didn't remember seeing the stem... since it doesn't fit a lot of rims.
Old Jan 13, 2004 | 08:38 AM
WashUJon's Avatar
WashUJon
That's true and it may be removable, but I'll bet Nissan will just replace the whole unit.
Rev_Night
Nov 7, 2020 06:00 PM
sales@czp
Sep 23, 2019 03:30 PM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
