Help! Weird clutch noise!!
Old Oct 31, 2012 | 12:50 PM
KRiSXC0RE's Avatar
KRiSXC0RE
Exclamation Help! Weird clutch noise!!
hey whats going on? My 350z is making a weird noise when I put the clutch pedal to the floor. Check out the video so you guys can see what I mean.
Let me know if you guys know what it is! Thanks again!
Old Oct 31, 2012 | 01:07 PM
flynzed's Avatar
flynzed
Sounds like you throw-out bearing. It engages when you press the clutch in. If you find you need to replace it you may also want to replace the clutch plate at the same time. Remember to have your flywheel milled to ensure it's smooth without any grooves in it.
Old Oct 31, 2012 | 05:28 PM
Jbakes727's Avatar
Jbakes727
I have a similar problem except mine is the opposite.
When my clutch pedal is out i hear a chattering noise but when i push it in the chattering noise goes away then when i let it back out again i hear the same noise. What could that be?
Old Oct 31, 2012 | 06:35 PM
Diesel350's Avatar
Diesel350
SAME EXACT THING Happens when I start my 2006 in the morning, I am wondering what the heck that sound is.
Old Oct 31, 2012 | 07:55 PM
ronn1's Avatar
ronn1
Could be your tranny/input shaft bearing. OPs problem is TOB related.
Old Nov 4, 2012 | 06:22 PM
KRiSXC0RE's Avatar
KRiSXC0RE
ahh man /: I really wanna know what the problem is exactly so I can just get it repaired already!
Old Nov 6, 2012 | 03:04 PM
KRiSXC0RE's Avatar
KRiSXC0RE
bump
Old Dec 9, 2012 | 02:31 PM
KRiSXC0RE's Avatar
KRiSXC0RE
bummp
Old Dec 9, 2012 | 04:49 PM
350zsunshinefl's Avatar
350zsunshinefl
since you have an 03 with probably high mileage (i am guessing over 100k?) , it's definitely the throw out bearing - all the factory grease is gone or almost gone by now.
Since this is a labor intensive job I'd also have the clutch disc changed and the flywheel resurfaced or replaced, but basically when the transmission is disconnected make sure everything is greased.
Old Dec 10, 2012 | 09:24 PM
KRiSXC0RE's Avatar
KRiSXC0RE
Yeah my 350z actually just hit 133k. Thanks for all the info! I really appreciate it. I do have one more question though, what exactly does getting a flywheel resurfaced mean? I've heard people mention that before but I'm not sure what it means /:
Old Dec 11, 2012 | 11:37 AM
oorc14's Avatar
oorc14
Hey guys I'm having a very similar problem like the one justin60222 described. After 10-15 mins of driving my 350z 07 when I press the cutch, the noise stops, when I release it it goes out, almost like a rattling noise. The more I use the clutch, the louder it goes. What worries me is the fact I just purchased it with 35,000 miles on it and the noise came in within my first 500 miles of use.. Any idea of what it can be? It would be really helpful!
Old Dec 11, 2012 | 11:41 AM
SilverStone2003's Avatar
SilverStone2003
Depends, aftermarket or stock clutch? Because my JWT clutch and flywheel sounds like a bunch of marbles usually. So do you have a whirring chatter, or slippage, or what?
Obadabot
Jun 18, 2023 11:31 PM
Uriyo_
Sep 8, 2021 08:46 AM
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
