Is something wrong with my transmission?
Old Nov 1, 2012 | 06:08 AM
Moussa93's Avatar
Moussa93
Default Is something wrong with my transmission?
Hi there,
Just wondering if something is wrong with my transmission?
When I'm at a stop sign or a red light, when I try to take off, or just accelerate quickly... (I don't do this every day... ... ) the car won't just go... ?
I mean, I will be on 1st gear, but around 6K RMP, the clutch pedal engages itself ? And when I go on 2nd Gear, I accelerate and then... nothing, just like the car is on Neutral ?
To fix it I have to go on Neutral, wait a little bit for the car to calm down and put 2nd or 3rd, match rev and accelerate... And then the car will go...
Someome ever experienced this?
Thank you
Old Nov 1, 2012 | 06:12 AM
KornerCarver's Avatar
KornerCarver
Thinking your problem might be the clutch.
Old Nov 1, 2012 | 07:58 AM
Jonnoh's Avatar
Jonnoh
first manual car?
clutch is gone.
Old Nov 1, 2012 | 08:19 AM
Mattysals's Avatar
Mattysals
Clutch
Old Nov 1, 2012 | 09:11 AM
ParanoidAndroid's Avatar
ParanoidAndroid
something here is VERY wrong. very wrong indeed.
Old Nov 1, 2012 | 09:30 AM
Deteria's Avatar
Deteria
Originally Posted by Jonnoh
first manual car?
clutch is gone.
Seems fit for a Bad Luck Brian meme
Old Nov 1, 2012 | 09:45 AM
Moussa93's Avatar
Moussa93
Yes, that's my first manual car, but I've driven manuals before.
I was stalling the first day, a lot, clutch was smelling very bad...
But now, about two weeks later, I drive it perfectly, shifting gears smoothly, and so...
Do you guys think that I killed the clutch during the first days oO ?
Thanks for your answers
Old Nov 1, 2012 | 10:03 AM
F34RL355's Avatar
F34RL355
i think u need a new clutch as well, seems to be slipping till 6k and then it catches
Old Nov 1, 2012 | 10:26 AM
Moussa93's Avatar
Moussa93
Update:
Just turned the car on, put on 2nd Gear, Ebrake on, tried to take off and the car stalled
Tried to change gear without the clutch engaged and it's hard as hell, so it has plenty of grip left
Should I conclude that the Clutch is still here?
I mean, car has only 60K miles and I made the clutch suffer for 2 or 3 days :/
Thanks
Old Nov 1, 2012 | 10:58 AM
Deteria's Avatar
Deteria
Maybe CSC is about to fail or VDC is on?
Old Nov 1, 2012 | 11:19 AM
Moussa93's Avatar
Moussa93
What is CSC? Slave Cylinder?
If yes, it has been replaced under warranty (recall) by the previous owne
And my TCS (Enthusiast) is always on.
Thanks
Old Nov 1, 2012 | 11:24 AM
iideadeyeii's Avatar
iideadeyeii
If you have to match RPM's to get it in gear from neutral then your clutch is gone
Old Nov 1, 2012 | 02:40 PM
oldschool350z's Avatar
oldschool350z
Sounds like you burnt the clutch out
Old Nov 1, 2012 | 03:39 PM
Spike100's Avatar
Spike100
Clutch is shot. You need a new assembly and pressure plate. --Spike
Old Nov 1, 2012 | 04:35 PM
KornerCarver
I would suggest taking your car to a competent mechanic and getting it checked. Diagnosis over the internet is difficult and you don't seem to believe your clutch is worn out. You stated the clutch was smelling pretty bad when you first started driving the car and that might have been enough to burn up the clutch. You have no idea how the car was driven by prior owners. I know you haven't had the car long, but still, the symtpoms sound like a burned up clutch.
Old Nov 1, 2012 | 05:19 PM
Spike100's Avatar
Spike100
Well stated and an excellent explanation. --Spike
Old Nov 1, 2012 | 06:44 PM
Moussa93's Avatar
Moussa93
Thanks people, will take it a mechanic to have it checked
Obadabot
Jun 18, 2023 11:31 PM
07ZEKE
Aug 23, 2021 09:15 PM
burglapfd
Dec 6, 2020 01:04 PM
