sputtering/jerking under light acceleration
Old Nov 10, 2012 | 06:53 PM
waikiki35's Avatar
waikiki35
Default sputtering/jerking under light acceleration
Hey,
I just got my first 350z about 1 month ago.
When the car is cold everything is smooth.
After a few minutes of driving it starts jerking in 1st and 2nd gear ( really bad in 1st) under light acceleration at around 2200 rpm. It feels like the car completely looses power right around there.
the only mods are injen intake and test pipes... thought it might be why because it probably never had a tune?
any ideas?
Thans for your help!
2003 touring 100 000 miles
Injen AI
Test pipes
Old Nov 11, 2012 | 03:17 AM
SuperZMachine's Avatar
SuperZMachine
Check for exhaust leaks, probebly a gasket. I had that problem before..
Old Nov 11, 2012 | 07:37 AM
waikiki35's Avatar
waikiki35
just checked, I did not find any..
Old Nov 12, 2012 | 06:08 PM
waikiki35's Avatar
waikiki35
Helppppppp
Old Nov 13, 2012 | 12:17 PM
amr_electron's Avatar
amr_electron
Check your coil packs as they tend to fail because of heat & will be more noticeable under load .
If you are losing power in low RPM but the car runs fine in higher RPM, Then you most likely have a vacuum leak.
Old Nov 13, 2012 | 12:52 PM
MUZZY's Avatar
MUZZY
clutch slip?
Old Nov 13, 2012 | 01:01 PM
0jiggy0's Avatar
0jiggy0
CHeck for intake leaks. Check engine light? Sounds like a coil pack to me.
Old Nov 13, 2012 | 02:49 PM
waikiki35's Avatar
waikiki35
Clutch doesn't slip and it gets worse the longer I drive.. Doesn't do it when car is cold. No ses or codes. If it was the coil pack it would do it when the car is cold as well wouldn't it? How do I check for vacuum leaks?
Old Nov 13, 2012 | 03:08 PM
zakmartin's Avatar
zakmartin
Could be a bad IAT sensor, could be a vac leak. Hook it up to a scan tool and a vac tester and run a diagnostic. The FSM will have a troubleshooting guide to walk you through it. If I were throwing parts at it, I'd say it's your IAT sensor, but throwing parts at a problem is not a good idea, so test everything first. If you don't have the equipment to test with, then find someone who does or just get a shop to fix it.
Also, did YOU install the intake? Did you muck around with the MAF sensor? That could be causing the problem too. Check all connections and make sure it's facing the right direction.
Old Nov 13, 2012 | 07:27 PM
waikiki35's Avatar
waikiki35
I did not instal it , I bought the car this way.. Unfortunately I am a student and do not have the money to take it to a shop.. How can I check the MAF sensor and IAT sensor myself ?
Thanks alot.
Old Nov 13, 2012 | 08:04 PM
waikiki35's Avatar
waikiki35
okay, did a little research and from what I understand the IAT sensor is in the MAF sensor.. should i just clean it and see from there?
Old Nov 15, 2012 | 05:25 PM
0jiggy0's Avatar
0jiggy0
Thanks alot.
With a scanner.
Old Nov 16, 2012 | 05:12 AM
waikiki35's Avatar
waikiki35
Originally Posted by 0jiggy0
With a scanner.
I did and they are fine...
Old Nov 16, 2012 | 01:57 PM
zakmartin's Avatar
zakmartin
Yeah, you can try cleaning the MAF, just be sure to use MAF Cleaner (dont' use carb or brake cleaner). The IAT can be cleaned with MAF Cleaner or carb cleaner. As long as you're in the engine bay, you should also clean out your throttle. Use throttle cleaner/lube. Valvoline makes a good cleaner for that. If you don't know how to do this, get on Youtube and look it up.
Before you do ANY work on your car, get a Factory Service Manual. You can get these on Nissan's website for 20 bucks and just download it to your computer so you'll always have it. It will pay for itself the first time you use it.
EDIT:
FYI, aftermarket air filters that use oil in their elements can really screw up your MAF. If possible, you should just stick with the factory airbox and filter. Nissan did a good job designing it and aftermarket intakes on the Z, though nice for show, do just about nothing to help with the car's performance. In a lot of cases, you'll lose power.
Old Nov 16, 2012 | 02:15 PM
2TH PWR's Avatar
2TH PWR
Unintentional LOL thread title
Old Nov 17, 2012 | 02:49 PM
waikiki35's Avatar
waikiki35
Hahahahaha!xD just realized that!
Anyways I used some RCR cleaner to clean out the sensors and it did not help at all...I already got a service manual thanks. And I bought the car this way so I do not have the stock intake.. I also cleaned the throttle body like you said.. Any other ideas? are you sure it has nothing to do with the fact that I got test pipes and cai and never got a tune?
thanks for your help!
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
