Relay for reverse light
Old Nov 24, 2012 | 06:33 PM
southerncadesi's Avatar
southerncadesi
Default Relay for reverse light
Hello everyone,
First and foremost I've spent a good part of the day searching. My reverse lights stopped working and I'm diagnosing the problem. Checked the bulb, and fuses.
I couldn't find the relay for the reverse light. Was wondering if anyone could direct me to it? I've seen some fuse/relay layouts for earlier model Z's but not one for an '06.
I know it might be the switch next to the transmission, but I'd like to check the relay before I go there.
Any help would be appreciated, thanks!
I have base 2006, manual.
Old Nov 24, 2012 | 08:37 PM
Bmurray350z's Avatar
Bmurray350z
did you look behind the battery compartment? not the ones on top of the battery, but actually behind the battery.
Old Nov 25, 2012 | 09:56 AM
Bober'z's Avatar
Bober'z
Hey man its the switch im 99% sure, relays dont usually go bad. I replaced my switch a year ago and its been fine ever since
Old Nov 25, 2012 | 12:03 PM
southerncadesi
Bmurray: I looked at the fuse box behind the battery, but the relays aren't labeled.
Bob: yeah looks like it'll be the switch just wanted to at least check the relay before I get under the car
Old Dec 5, 2012 | 08:09 AM
3five0zee's Avatar
3five0zee
i'm having the same issue. new to the forums! where is the reverse light switch located? right by the transmission correct?
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
