Switching to Synthetic oil at 40k??
Old Jan 23, 2013 | 11:59 AM
klenkart's Avatar
klenkart
Default Switching to Synthetic oil at 40k??
I have a 2008 hr with about 40k on it. I had an issue with oil pressure due to clogging of some ports near the timing chain cover which was fixed by the dealer. Im wondering if I can switch to synthetic with 40k miles. Anyone know if this will cause any issues? Ive seen in other threads people making the switch but they all had lower miles.
Old Jan 23, 2013 | 01:42 PM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
I switched to synthetic at around 50k miles. At 85k now with no problems. I have a DE by the way; don't think it matters though.
Old Jan 23, 2013 | 01:51 PM
silverbullet_Z's Avatar
silverbullet_Z
it will blow up your car dont do it.
Old Jan 23, 2013 | 09:26 PM
pro_350z's Avatar
pro_350z
you should be fine
Old Jan 24, 2013 | 09:25 AM
TPete19's Avatar
TPete19
Originally Posted by pro_350z
you WILL be fine
Fixed. You will not see any ill effects.
Old Jan 24, 2013 | 09:55 AM
Waiz's Avatar
Waiz
Makes no difference regardless of miles
Old Jan 24, 2013 | 12:56 PM
Jbakes727's Avatar
Jbakes727
Even if I switch to full synthetic at 85k miles I'll be ok? (04 DE)
Old Jan 24, 2013 | 02:00 PM
zakmartin's Avatar
zakmartin
You can switch back and forth between synthetic and dino without any problems. Synthetic oils don't cause the problems they used to, especially on newer cars.
Old Mar 19, 2013 | 07:36 AM
Jbakes727's Avatar
Jbakes727
Switched to full synthetic on my 04 Z at 84k miles. Put about 300 miles on the new oil and so far the dipstick reads perfect with no oil consumption.
Old Mar 19, 2013 | 11:10 AM
redline06's Avatar
redline06
switch to synthetic? my first oil change was synthetic, i thought thats what it calls for anyway
Old Mar 19, 2013 | 11:19 AM
andre12031948's Avatar
andre12031948
Default clogging of ports ???
More important, what did you use before? Mud?
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
Stevo Z
Oct 3, 2015 09:14 PM
