no power inside car, can it be a ecu issue?
Old Feb 14, 2013 | 04:17 PM
Calinismo350z's Avatar
Calinismo350z
Default no power inside car, can it be a ecu issue?
This morning when I was gonna turn on my car I had my key on ACC and all the gauges and stereo was working right but as soon as I turn my key to start the engine all the power went out. my battery is brand new I already test it and it has power but inside the car nothing turns on no lights, no stereo.. nothing!! I already checked all the fuses outside/inside and they are all good. can a burn or messed up ecu be the issue?
Old Feb 15, 2013 | 08:54 AM
Tracktimeplz's Avatar
Tracktimeplz
Everything Stock? Stock Stereo, lighting, ect?
Old Feb 15, 2013 | 09:01 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
So your gauges, stereo and climate controls do not work but your car turns over fine and all the exterior lights turn on?
Old Feb 15, 2013 | 10:11 AM
Calinismo350z
found the problem after spending all valentines day working on it. it was the relays on the power cable. replaced them with the ones from my Altima and everything back to normal I'm gonna have to order them from Nissan. thanks a lot guys!! now I'm gonna go get the drag slicks mounted on the new 15 wheels and see the results since its my first time on drag tires.
Old Feb 15, 2013 | 10:30 AM
Calinismo350z
nothing was working at all!!! no lights, no cluster, no power at all inside car, for a sec I thought it was the ECU since I had the split sec piggy back but I took it off about 5 months ago and got tuned with uprev. but thanks god I found the problem I was about to take it to Nisan.
Old Feb 15, 2013 | 11:27 AM
Tracktimeplz
hmmm, I wouldnt imagine that those go out under normal conditions, hopefully you dont have a bigger problem thats taking them out.
Grats on the find though, and post up your results when u hit the track
Old Sep 15, 2013 | 09:44 AM
DOSXX's Avatar
DOSXX
Got the same problem. The worst was that I am a handicap and the car died in the middle of the road and on traffic. I chk the battery and read 12.8v (2 mo. old). You say it is a RELAY on the power cable?
Old Sep 15, 2013 | 10:36 AM
oldschool350z's Avatar
oldschool350z
Not sure if he will reply because it's an older thread. .
etkms
Jun 19, 2022 06:30 PM
aarrgghh
May 1, 2022 11:04 AM
D-ray
Sep 17, 2015 07:27 PM
RyansZ33
Sep 15, 2015 05:54 AM
PureR3d
Sep 10, 2015 06:23 PM
