Replacing Valve Covers... Should I Replace More?
Old Feb 22, 2013 | 03:09 PM
Shoji's Avatar
Shoji
Default Replacing Valve Covers... Should I Replace More?
Title says it all.
I have a 2003 mostly stock VQ35DE (non-Brembo) with just under 135,000 miles. Oil is getting into the spark plugs wells and messing with the spark plug ignition on the rear-most driver-side plug. I literally just had the Nissan Dealership install new plugs at the 130,000 mile mark.
Plan: Replace Valve Covers.
Extras thanks to tax return:
- Motordyne 5/16" copper iso thermal spacer
- MREV2
- R1 Concepts Cross-Drilled/Slotted Rotors
- Hawk HPS pads
Thoughts: Should I go ahead and tear off the heads and replace the head gaskets? I do not drive it recklessly, although every now and then I will go full throttle from 0 to "5 over" the speed limit. I have maxed out the engine (top speed) going to the hospital or racing to some other emergency 3 times in the 7 years that I've owned it. I have never had any other problem with the engine; just the oil messing with the one spark plug.
Random other upgrades currently on the Z:
- JWT Pop Charger
- JWT Clutch and Lightweight Flywheel
Old Feb 25, 2013 | 12:49 AM
RENFRO's Avatar
RENFRO
Is your exhaust spewing out white smoke at all? Usually that's a good sign of coolant getting into your cylinders from a bad head gasket. I wouldn't think you'd need to go through all of that. However if you did, make it worthwhile and get some headwork done (maybe a stage 1 or 2 setup) with a nice street cam, arp head studs, and fresh gaskets. I wouldn't want to go through the whole deal of taking the heads off just to put it back to stock specifications
Rev_Night
Nov 7, 2020 06:00 PM
350z82
Oct 1, 2015 06:25 PM
