Overheated from accident...
Old Mar 8, 2013 | 07:58 AM
tennis_pr0's Avatar
tennis_pr0
Just called the mechanic, he said he did a pressure test on the cooling system, he said if the head gasquet was weak it would have showed up in that. I asked him about the compression test on the cylinders, he said the engine it running fine and that wasn't necessary. He said there was no water or anythuing in the oil as well, and the engine is 100% fine. Does this all sound right?
Old Mar 8, 2013 | 08:35 AM
dkmura's Avatar
dkmura
General & DIY Moderator
A pressure test of the cooling system can only check for readily apparent problems with the radiator, coolant lines and passages. It WILL NOT determine the overall condition of your VQ the way a leakdown test will. It sounds like you want some additional assurance your engine was not damaged. If so, a leakdown test can help determine that and you'll need to find a competent shop to perform one and explain the results to you.
Old Mar 8, 2013 | 08:51 AM
tennis_pr0's Avatar
tennis_pr0
Ok so a leak down test. What about the compression test on the cylinders?
Old Mar 8, 2013 | 09:03 AM
tennis_pr0's Avatar
tennis_pr0
If I go to the dealership and do a compression and leak down test how much would that probably cost?
Old Mar 8, 2013 | 09:27 AM
godzilla619's Avatar
godzilla619
most shops will charge you $150-$300 depending on thier labor rate. dealership is going to charge you $300-$500. in all honesty if they do find a problem are you going to spend the $2k to fix your engine, for something you can't notice while driving? if not why waste your money on the tests?
Old Mar 8, 2013 | 09:38 AM
tennis_pr0's Avatar
tennis_pr0
I understand your point, but won't that hurt my engine long term if there is something wrong?
Old Mar 8, 2013 | 01:55 PM
dkmura's Avatar
dkmura
What people are saying here is that if your engine suffered some damage, there's not much you can do about it unless you're willing to do a full rebuild. A leak down test will give you an idea if compression across all cylinders is equal. If they results are wildly off, you could be driving on borrowed time. All engines begin to suffer from wear from time, heat and stress, so don't expect perfect results. Look for a good independent Nissan garage to perform this test (might want to change out your NGKs while they're at it if you're anywhere near 100K) and explain the results to you.
Old Mar 8, 2013 | 03:51 PM
tennis_pr0's Avatar
tennis_pr0
Is a leak down test the same thing as a compression test? If not, i will get both a leak down test and compression test and post the results on here
Old Mar 8, 2013 | 06:17 PM
tennis_pr0's Avatar
tennis_pr0
Ok so let me get this all straight. I had the pressure test, and will get the results to that and put them on here. I will also get a leak down test and a compression test. Once I have all those tests done, and I check to oil and it isn't that chocolate color, if all these things pass, then the engine is perfectly fine? There isn't anything else to check for?
Old Mar 8, 2013 | 06:20 PM
tennis_pr0's Avatar
tennis_pr0
Also I just want to make sure I have this correct, but there are two types on compression tests? One on the cooling system and the other on the cylinders? The pressure test of the cooling system tests for head gasket failure right? Isnt this what a leak down test would do? If I already had the head gasket tested from the pressure cooling test, then do I still have to get the leak down test? Please help me with this stuff guys I don't know anything about engines and am concerned. Thank you so much in advance.
Old Mar 8, 2013 | 06:47 PM
tennis_pr0's Avatar
tennis_pr0
http://www.benplace.com/pressure_test.htm
Old Mar 10, 2013 | 01:58 PM
tennis_pr0's Avatar
tennis_pr0
So I called Pep Boys, and they said a dry compression test is 50 dollars, and the leak down test is also 50 dollars. I will take it there tomorrow and get those two tests done and then post the results on here. From the information I have read, a wet compressin test is only necessary if the dry compressions tests numbers are off because that will find ou where the problem is. So if the dry compression test and the leak down test come back good, then my engine did not suffer any damage from the overheating, is this correct?
Old Mar 10, 2013 | 02:02 PM
0jiggy0's Avatar
0jiggy0
sure
Old Mar 10, 2013 | 02:11 PM
tennis_pr0's Avatar
tennis_pr0
I just want to make sure I am doing everything correct as i don't know anything about engines and really care about my car
Old Mar 10, 2013 | 03:50 PM
tennis_pr0's Avatar
tennis_pr0
catostrophic failure yes you would notice. weakening the head gasket but not completely breaking the seal, no wouldn't notice driving normally. you wont know till you drive it aggressivley or over time and something bad happens. ethier way you were the cause so just drive it normaly and be vigilant of checking your oil and coolant for any change in levels or unusual color. if your engine does let go early you know the cause.
The pressure test of the cooling system, doesn't that test for head gasket problems?
Old Mar 12, 2013 | 11:19 AM
tennis_pr0's Avatar
tennis_pr0
So they tested to cooling system and everything was good, and also did a compression test. He said they all came back right around 152, and the factory specs should be from 142-185. I have a 2006 automatic with 50k miles on it. They said the only thing that wasn't working was the fan which is why it overheated a bit today.
Old Mar 12, 2013 | 12:19 PM
terrasmak's Avatar
Radiator was replaced in the accident and overheats now, very simple. Bleed the cooling system, you have an air pocket. Most people do not know how to properly do this on a Z
Old Mar 12, 2013 | 12:32 PM
  #38
tennis_pr0's Avatar
tennis_pr0
Yeah that's what this place said, they said I had an air pocket. They bled the cooling system and then reved the car up. The fan they said did not work though, so that is getting replaced.
Old Mar 12, 2013 | 12:35 PM
  #39
tennis_pr0's Avatar
tennis_pr0
They bled the system then reved it up until the thermostat opened up, I just called them and that's what they said.
Old Mar 12, 2013 | 04:02 PM
  #40
terrasmak's Avatar
There is also a bleed port off the back of the heater hose that needs be to used to get the air out. Tell then about it, many do not know. Pass side near firewall.
bneumann
Oct 7, 2015 12:16 PM
n666
Apr 27, 2010 09:50 AM
joshp214
Jun 5, 2006 09:40 AM
Gman2004
Oct 26, 2005 05:22 PM
koolzero
Feb 26, 2005 11:39 AM
