Service engine light on
Old May 23, 2013 | 02:21 PM
MyO3Z's Avatar
MyO3Z
Originally Posted by jhowald93
look to why the o2 sensor causes the PCM to throw a code ( o2 doesn't throw codes @myo3z) and don't go directly to thinking the o2 is bad
That's what I meant...that the information the O2 sensor is sending back to the PCM/ECU is not within specs aka the O2 sensor is causing the light to come on, but is not necessarily the issue.
Old May 23, 2013 | 03:44 PM
jhowald93's Avatar
jhowald93
Yeah I know that's what you meant just didn't want others to think otherwise xD
Old Jun 6, 2013 | 03:02 AM
SD350dude's Avatar
SD350dude
Originally Posted by Syner
Good luck, based on that outburst you won't be getting any help from me.
EDIT - zakmartin is one of the more helpful and mechanically inclined/savvy individuals on this site. Think about what you are posting before you start burning bridges.
I'm Open to help, but I'm not open to people being jackasses on the internet, which is what the case was here...
Old Jun 6, 2013 | 03:04 AM
SD350dude's Avatar
SD350dude
how does a shop go and test all that stuff? If its a misfire wouldn't it be tripping other sensors? How can a shop tell if its an injector that's clogged, or a spark plug that isn't firing all the way or is giving a weak spark?
Old Jun 6, 2013 | 03:33 PM
350zx6r's Avatar
350zx6r
i got a service engine soon light, should I get my oil changed? j/k people need to manner the way they "try to help" other, sometimes your answer gets across the board in a very different way.
i got that light for like 2 days and then it disappeared. I will get it checked out because I believe even if it goes away it gets recorded right.
Old Jun 9, 2013 | 07:20 PM
SD350dude's Avatar
SD350dude
So I had a shop quote me 375 to replace the A/F sensor, which I've already had replaced once by a shop down the street... which I'm never going to again because the guy got my car stuck on the lift while he was trying to drive it up... ****ing retard... light came back on after the sensor was replaced, and now this 2nd shop is telling me to replace the sensor with a higher quality one. 1. Is this shop just trying to hassle me into spending more money then I need to. 2. What kind of warranty should I look into with the shop if the code keeps coming back? 3. Are there steps the shop should take to diagnose why the code is coming up? Should they test the plugs, coils before I have them replace the A/F sensor AGAIN?
Uriyo_
Sep 8, 2021 08:46 AM
Fixxxercask
Nov 9, 2015 11:10 AM
350z82
Oct 1, 2015 06:25 PM
samansharif
Sep 25, 2015 12:31 PM
