Clutch will be replaced in '05 roadster. Should we replace anything else?
This is my daily driver.
I don't want a lightweight flywheel combo as from the various videos and threads I've seen, the chatter noise would be annoying for a daily driver.
I am looking for a good clutch though. Maybe just go OEM? Which brand?
Should we replace any other parts while we have everything opened up?
Thanks all.
Thanks all.
While your in there replace the pilot bearing in the back of the crankshaft and the throw out bearing. Cheap parts but good insurance if they decide to let go a few thousand miles after you replace the clutch. You know Murphy's law. But with a proper clutch kit a throw out bearing should come with both. Along with a pressure plate.
I just went with a Southbend clutch and flywheel, check the VQ35 section.I put up a short vid,chatter is same as stock.
Not sure if the 05 have the internal slave, if so you may want to replace that as well.
Good luck.
Good luck.
