Quick question: Trans/Diff Oil ?
Old Jul 17, 2013 | 05:52 AM
chuquison's Avatar
chuquison
Question Quick question: Trans/Diff Oil ?
I am changing out my clutch with a JWT clutch since I am not planning on doing anything special for a while.
I wanted to know what brand of Oil do you recommend for the transmission since I will drain it out and the Differential as well. I am pressed for time so I don't think I have time to order something and get here Tuesday. but if I had to go to a local place to get some, Autozone, Discount auto kinda places what do you recommend? also the weight and stuff would be help full..
I typed "Best Transmission Oil" in search but couldn't find much
Old Jul 17, 2013 | 06:27 AM
Touge Z's Avatar
Touge Z
redline oil is good for the trans and diff. you should be able to get it at your local auto parts store too.
Old Jul 17, 2013 | 07:13 AM
binder's Avatar
binder
I use redline oil. Use the GL5 in the rear end and GL4 in the transmission. Without heading over to the shop I couldn't tell you which one is which. I'm pretty sure I run MT90 in my trans which is a little thicker than stock but I don't drive the car in the winter. I don't remember what I used on the diff for weight. I think there is a thread about it on here and I posted what I run. It works really well. Very smooth shifting.
Old Jul 17, 2013 | 07:17 AM
binder's Avatar
binder
Ah, People used to mix them to get the thickness we need but now that I checked their site Redline makes the proper one: MT85. It's gl4 in the proper oem weight for the transmission.
75w90 gear oil from redline is what I use in the differential. GL5 and proper weight. Summitracing.com has them in stock at a good price.
I think you need just over 3 bottles for the transmission and just over 2 for the differential. I always keep extra on hand so I do'nt really pay attention to how much it takes when I change the fluids.
Old Jul 17, 2013 | 08:21 AM
oldschool350z's Avatar
oldschool350z
Yeah I agree with redline it's all I've ever used on my cars. Just make sure you get the right weight and gl type
Old Jul 17, 2013 | 08:35 AM
chuquison's Avatar
chuquison
thank you guys ill try ordering it now, so I am getting GL4 4 bottles for trans and 3 bottles of gl5 for diff is this correct?
Old Jul 18, 2013 | 06:53 AM
HK350 Z's Avatar
HK350 Z
I use Motul 300 in the tranny and Nissan OEM fluid in the diff.
Old Jul 18, 2013 | 08:40 AM
binder's Avatar
binder
That sounds correct to me.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
