SES light after Dead Battery, Please help
Old Jul 20, 2013 | 09:08 AM
whitezd01's Avatar
whitezd01
Default SES light after Dead Battery, Please help
ok guys this is my first time posting on here so Im sorry if this question has already been asked, but i searched and couldnt find anything on it.
im sure the answer is easy but im just a little worried about my baby.
so the last few days my car, which is a 2007 350z enthusiast, has taken a couple extra seconds to start, i assumed i just needed a new battery but wasnt worried about it. so this morning i went to get gas before work, got gas, then my car wouldnt start. I got a jump and now my Service engine soon light is on. I ran the code at work, P0603, which basically means theres a problem with the power supply circuit i guess.
Could this light be coming on simply because i need a new battery, which is being installed right now or because there is a larger issue, like the ECU or a bad connection? My car has never had any issues before and was running fine after the jump, nothing out of the ordinary.
any help here would be great, im just a little worried and dont want to go back to nissan not knowing what im talking about.
Old Jul 22, 2013 | 12:30 PM
zakmartin's Avatar
zakmartin
It should be fine after you install your new battery. You weren't carrying enough voltage to the PCM, so it tripped the CEL. When in doubt about your battery, have it tested with a carbon pile load tester to see if it's still good or not.
Old Jul 23, 2013 | 04:40 AM
Bret86944's Avatar
Bret86944
Your battery is dead. I'm not surprised your car thinks there is an electrical problem. Replace the battery.
Old Jul 23, 2013 | 08:23 AM
flynzed's Avatar
flynzed
The same thing happens if you use a quick disconnect over the winter. You get an SES light with a report of a short or loose battery post. If you want to get rid of it quick stop by an auto parts store that lets you use a a scanner and reset the system.
Old Jul 24, 2013 | 01:38 AM
Yes. Simple fix.
Old Oct 18, 2013 | 09:34 AM
slowstang06's Avatar
slowstang06
Hey! Sorry to revive this, but did the above work? I have a 2008 base that had the same problem (took longer to start and then just wouldn't start anymore). I had AAA jump it and then put in a new battery but I still have the P0603 code, which I looked up and it was regarding a memory error.
EDIT: I found this link: http://www.underhoodservice.com/Arti...er_supply.aspx
I'll give it a shot with a regular scan tool
Old Oct 18, 2013 | 02:52 PM
oldschool350z's Avatar
oldschool350z
This happens to me when I disconnected my battery during winter
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
samansharif
Sep 25, 2015 12:31 PM
