Oil pump issues. . ?
Old Oct 23, 2013 | 04:04 PM
MJ_350z's Avatar
MJ_350z
Default Oil pump issues. . ?
I have a VQ35HR and I have problems with the oil pressure and I want to know if the oil pump is damaged, I did a test, take a line of oil in a turbo and I crank the engine and no oil came out, the pump will be damaged or in these cars does not leave oil pressure to start the engine, how could know if the pump is broken?
Old Oct 23, 2013 | 04:43 PM
jerryd87's Avatar
jerryd87
you check the oil and see if it has shards in it, your going to need to crank it quite a bit for any oil pressure too just cranking it a little isnt going to do much. why didnt you ask both questions in one thread? seems like you built a engine and already think you toasted it.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
