Tranny replacement 03
Old Nov 15, 2013 | 04:42 PM
375rngrZ's Avatar
375rngrZ
Default Tranny replacement 03
I have an 03 an I'm pretty sure the tranny is on it's way out so after reading a few threads I've seen people say to put a cd009 in. Since I'm not very familiar with trannies my questions are what else will I need besides the cd009 for the swap? What can I expect to pay for labor if I buy the tranny clutch and flywheel before? And what should I pay for that tranny? Thanks guys I'm pretty new when it comes to trannies so please don't flame me lol
Old Nov 16, 2013 | 11:40 AM
Spike100's Avatar
Spike100
The 2003 was notorious for transmission problems. Some owners had the transmission replaced under the manufacturer’s warranty (Nissan replaced mine).
You don’t have to replace the clutch assembly if the components are in good shape. I replaced my transmission at around 36,000 miles and did not replace any of the clutch components. I’m at 88K miles now and the clutch is still fine.
A used transmission will cost anywhere from $1,000-$2000. You definitely want the updated transmission since it shifts more smoothly. Your labor costs to install a transmission can vary significantly depending upon who does the job. The dealership will be the most expensive, but you get a warranty.
Question: Why do you believe that your car’s transmission needs to be replaced?
Spike
Old Nov 16, 2013 | 05:33 PM
375rngrZ's Avatar
375rngrZ
Spike
I'm getting the famous vibration on deceleration. It's becoming more and more frequent and I was reading up on here and someone took theirs into the shop and they said it was the tranny. I still have a decent amount of time before my tranny is toast but I figure I mines well start assembling the new parts so when it does go out I have it all
Old Nov 16, 2013 | 05:53 PM
Spike100's Avatar
Spike100
^^ Vibration when decelerating might have nothing to do with the transmission.
If you detect vibration when slowing, it’s likely that your wheel bearing are bad.
--Spike
Old Nov 16, 2013 | 06:22 PM
oldschool350z's Avatar
oldschool350z
Was the tranny in the 2004 any better?
Old Nov 17, 2013 | 12:16 AM
375rngrZ's Avatar
375rngrZ
--Spike
If you pump the clutch it goes away so chances are it isn't a wheel bearing
Old Nov 17, 2013 | 10:44 AM
Spike100's Avatar
Spike100
^^ Maybe it's your clutch assembly causing the problem?
--Spike
Old Nov 17, 2013 | 11:07 AM
Spike100's Avatar
Spike100
There were problems with the synchromesh in the 2004 transmissions. Nissan also replaced some of the 2004 transmissions.
The main symptom is grinding when downshifting (usually 6th to 5th). The pre-cd009 transmission also felt “notchy” (meaning it did not shift smoothly).
--Spike
Old Nov 17, 2013 | 11:25 AM
oldschool350z
Yes that's the first thing I noticed when driving the z is how notchy it feels.
Old Nov 18, 2013 | 02:07 PM
375rngrZ's Avatar
375rngrZ
--Spike
Hopefully but I like to prepare for the worst lol
Old Nov 18, 2013 | 03:57 PM
oldschool350z
Even if it's the clutch that's a big expense!
But don't go to the dealer lol. They wanted to charge me $1,500 to do the clutch because mine "catches too high". It doesnt slip or make noise they said it needs to be replaced. Liars.
Rev_Night
Nov 7, 2020 06:00 PM
350z82
Oct 1, 2015 06:25 PM
pr_350z
Oct 1, 2015 05:03 PM
