Pulsation HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Nov 18, 2013 | 06:17 PM
Nic Cassel's Avatar
Nic Cassel
Default Pulsation HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I have a 2003 with 66,000 miles
I took it in because my passenger side ramped up on the curb and came straight back down at about 30 mph
I noticed a pulsation over 50 mph. It happens when I cruise, brake, accelerate over 50 mph. its a constant tempo regardless of speed and stops only when I reduce speed below 50 mph. It seems as if I have to let it warm up at a high speed for it to begin, but once it does begin, it doesn't stop until I'm under 50 mph.
took it in and they balanced, aligned, visual inspection ... the works and its still happening. Brakes checked and replaced 3 months ago.
any ideas?
Old Nov 19, 2013 | 03:40 PM
Spike100's Avatar
Spike100
If the alignment and tire/wheel balancing is done correctly, and you still have vibration above 50 mph, something in the front suspension is bent.
The reason the alignment appears to be correct on the alignment-device (but the car is actually out of alignment) is simply a bent suspension component.
Sorry to tell you this, but the repair is going to get expensive.
--Spike
Old Nov 20, 2013 | 12:52 PM
Nic Cassel's Avatar
Nic Cassel
What about the wheel bearing assembly on the front?
Old Nov 20, 2013 | 01:27 PM
Spike100's Avatar
Spike100
What about it?
Old Nov 20, 2013 | 01:58 PM
Waiz's Avatar
Waiz
Check for a bent wheel too
Old Nov 20, 2013 | 02:11 PM
Nic Cassel's Avatar
Nic Cassel
Originally Posted by Spike100
What about it?
Could it be the wheel bearing assembly? can running on a curb damage that?
Old Nov 20, 2013 | 02:13 PM
Spike100's Avatar
Spike100
Good point…. People believe that a bent wheel results in tire pressure loss. That is often not the case. The bent wheel maintains tire PSI, but makes alignment impossible
--Spike
Old Nov 20, 2013 | 02:18 PM
Spike100's Avatar
Spike100
Yes. In fact that is an expected result when striking a curb. --Spike
Old Nov 20, 2013 | 05:40 PM
Nic Cassel's Avatar
Nic Cassel
I am going to put it on the lift friday. I will let you know what I find. Thank you guys! Please look saturday for my follow up
sry110
Dec 1, 2020 05:30 AM
Puretek
Nov 1, 2013 02:58 PM
350zbehold
May 20, 2011 05:49 AM
vie2233hil
May 3, 2005 01:34 PM
