Did I blow my lower oil pan gasket?
Old Dec 13, 2013 | 09:58 AM
xmartyx's Avatar
xmartyx
Default Did I blow my lower oil pan gasket?
I've got a 2003 Enthusiast and I bought it back in July. It has just a tad over 80,000 on it. I don't know what the previous owner ran in it, but when I got it the oil had last been changed at just an average used car dealership. I'm guessing nothing "fancy" was put in. When it was due I put Mobil1 0w04 in it. Everything was fine. I did a change at the beginning of November and parked it for a week cause the weather was terrible. Had a nice Sunday so I pulled it out, noticed a small spot and figured it was just cause a a tad bit dripped down while I was filling it. Drove for an hour or so and then put it away for the winter. A week later I checked under it and there was a huge spot this time.
It's a nice 25 degree day today so I decided to jack it up and see if something didn't get tightened. Everything seems to be tight. It's probably not the easiest to tell, and I know no one can tell for sure, but from the pictures, does it look like seal is leaking? I wiped it off and will check again in a week, but it just seemed to have oil on the side of the drain plug.
Also, I know these cars have the RTV seal, but I was just going to order a gasket from Advance. Does it really make any difference if you go with RTV or gasket?
Thanks for any help.
Old Dec 13, 2013 | 10:16 AM
djamps's Avatar
djamps
Looks like it's also coming from the filter sandwich plate or somewhere else higher than the pan gasket. A little bit on the upper pan seal too.. My 130kmi Z leaks from about everywhere possible. Just got used to it and wash it off every oil change so I can see where it's coming from. If anything, have the filter and/or sandwich plate checked out, high pressure oil in there that could cause some serious oil loss down the road.
Old Dec 13, 2013 | 01:36 PM
xmartyx's Avatar
xmartyx
So I basically should back off using the 0w40?
Old Dec 13, 2013 | 01:49 PM
Jbakes727's Avatar
Jbakes727
I run 10w30 mobile 1 in my DE at 92k and it burns a little oil not much but definitely no leaks in my driveway.
Old Dec 13, 2013 | 06:35 PM
NOLAGG's Avatar
NOLAGG
Same here , living I. Nyc climate changes every couple of months . No leaks , oil pressure is spot on and car still pulls like a train with a tiny bit of oil burning in the process just hit 100k and am running mobile1 10w30 as well all year around .
Old Dec 14, 2013 | 05:19 AM
xmartyx's Avatar
xmartyx
Does anyone know if there's just a seal on the filter sandwich plate and if it's easy to change, or is it a big ordeal and I probably messed a bunch of stuff up running that oil? I see a $4 O ring for the sandwich plate on Advances site. Would that do the trick?
Old Dec 14, 2013 | 07:59 AM
Arsenal350's Avatar
Arsenal350
Id goto the dealer for the o-ring behind the oil cooler. Thats all you need. Plus its only like 6-7 bucks from the dealer.
Old Dec 19, 2013 | 05:05 AM
xmartyx's Avatar
xmartyx
Does anyone know if I replace all the seals, would it be fine to run the 0W40 then or will I keep blowing them?
Old Dec 19, 2013 | 05:46 AM
NOLAGG's Avatar
NOLAGG
Why are you running that and not what's called for the car ?
Old Dec 19, 2013 | 08:05 AM
xmartyx's Avatar
xmartyx
I read through the big oil thread on here and it seemed like the mobil1 0W40 was the best for our cars.
Old Dec 19, 2013 | 11:38 AM
NOLAGG's Avatar
NOLAGG
I don't know man , to each their own butt car has 100k using mobile 5 or 10-30 and I never had an issue knock on wood *.
People also said using Diesel engine oil is "great " for our engines , but in reality your going to take a chance cause someone was lucky ? Up to you I would stick what was meant for the car especially cause your pretty much stock no?
Old Dec 19, 2013 | 02:29 PM
xmartyx's Avatar
xmartyx
Yea, bone stock minus intake. I'll be switching to mobil1 10W30 I guess.
Old Dec 19, 2013 | 04:06 PM
zakmartin's Avatar
zakmartin
5W30 for normal use. 0W30 if it's really cold outside. Mobil1 is as good as anything else and they carry both viscosities. Be sure to replace the crush washer each time you do an oil change and use a good filter. I agree that the O-Ring could be the problem. If it were me, I'd clean the whole area with engine cleaner and then use UV dye and a light to find the source of the leak.
Old Dec 19, 2013 | 04:11 PM
350slug's Avatar
350slug
My g had this issue and it kept getting worse. Yes there is a ring behind the oil cooler. It's cheap. I looked for the part number but couldn't find it. It was easy to do to I had just changed my oil right before it went so I had to do another change less than 1k miles.
Old Dec 19, 2013 | 04:17 PM
350slug's Avatar
350slug
This is the old one, the new one is black
Old Dec 19, 2013 | 04:23 PM
350slug's Avatar
350slug
Sorry for the bad pic but this is from the fsm
Old Dec 20, 2013 | 10:17 AM
xmartyx's Avatar
xmartyx
Originally Posted by 350slug
Attachment 359154
That's perfect. Thanks a ton.
Old Dec 20, 2013 | 10:40 AM
350slug's Avatar
350slug
u bet
burglapfd
Dec 6, 2020 01:04 PM
