Oil pressure at ACC?
Old Mar 1, 2014 | 04:36 PM
OneLovelyZee's Avatar
OneLovelyZee
Default Oil pressure at ACC?
Hi everyone,
My oil pressure gauge is reading at 60psi on start up. It goes to about 100 psi when driving 70mph.
I've read threads about it being the sensor. Is that what it could be in this case?
Does anyone know what the oil pressure gauge is supposed to read at when the key is halfway turned? Don't remember if it's supposed to be 0 or 60
It's a little chily today and I noticed a little bit of black smoke towards the higher end of the rpm range. Is that normal?
Old Mar 1, 2014 | 08:15 PM
350ZZJoe's Avatar
350ZZJoe
If the car is not running it should be at 0.
If it is running, it should be about 15psi at idle and about 45psi at 2000rpm under load. Type of oil you are using etc will make slight changes to this.
If your car reads 60psi before the engine is running, the sensor is probably bad. Really easy fix, had to replace mine last year and it fixed the same problem you are describing.
Old Mar 1, 2014 | 08:42 PM
terrasmak's Avatar
We may need an official oil pressure thread
Old Mar 2, 2014 | 03:18 AM
myfirstzcar's Avatar
myfirstzcar
That's exactly why a lot of cars don't have an op gauge. They even had to change the gauge on the Titans so they read half way all the time. People just don't understand.
I think the OP's car needs a sending unit.
Old Mar 2, 2014 | 06:18 AM
fklentz's Avatar
fklentz
I've had to replace mine twice so far. If you run a heavier oil and when you start it up cold the pressure will "peg" the sending unit, I'm guessing that is what happens, mine failed when I was running 40 weight oil.
Old Mar 2, 2014 | 07:22 AM
waldo36's Avatar
waldo36
I was about to post about my issue, but I'll just comment on here.
I have replaced my sending unit, but my needle still jumps around during normal cruising. And will fall flat out to 0 until I tap the top of the gauge, then it jumps to normal reading. I think at this point it has to be something electrical causing the needle to jump like this.
Old Mar 2, 2014 | 09:16 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Never had an issue with mine. Don't really go by either
Old Mar 2, 2014 | 01:09 PM
myfirstzcar
Yeah mine works great, never had an issue....Running 0w40.
Old Mar 3, 2014 | 02:31 AM
tcode's Avatar
tcode
Mine works too. Running 10W50.
Old Mar 3, 2014 | 03:32 AM
POS VETT's Avatar
POS VETT
I run 0W-40 & the gauge is pegged immediately after a cold start regardless of ambient temperature.
Old Mar 3, 2014 | 07:25 PM
WSchli1672's Avatar
WSchli1672
My .02 worth. I run Valvoline 10w30 and never a problem - S/C Vortech. Driven in 100 degree down to 45 degree. As mentioned above Post #2 type of oil is a littler determination, but not major. When in doubt see an expert. (Northern CA. I see Rob at ZCargarage as an example). Takes them only a minute to give you expert information.
Old Mar 4, 2014 | 02:58 AM
2004Black350z
Exhaust Whore
10w50 10w30 0w40 lol don't wanna start a oil thread but dam why not 5w30
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
