Hello I have a blue smoke issue on my Z
Old Mar 28, 2014 | 02:26 PM
Spike100's Avatar
Spike100
^^ If you see blue smoke from the exhaust and use oil, your engine is burning oil.
A common fix is a short block engine replacement.
I would take the car to a trusted shop and ask them the best solution for the problem.
--Spike
Old Mar 28, 2014 | 02:59 PM
myfirstzcar's Avatar
myfirstzcar
You need to have a leakdown test done on all 6 cylinders to determine if you need head work or a short block. A simple compression test may not reveal worn rings like an actual leakdown test would. If only one cylinder leaks down you may discover a problem with one of the heads, like a bad valve, vs a problem with all 6 cylinders. A bad valve may not make any noise either, but could have a bad seal allowing oil to be burned. It's rare to have one piston with worn rings, they usually wear evenly.
Before I forget, try a new pcv valve, they're known to cause oil burning on Titans....ask me how I know lol.
Old Mar 28, 2014 | 03:06 PM
npr350z's Avatar
npr350z
How do you know?
Old Mar 28, 2014 | 04:02 PM
trisk12's Avatar
trisk12
Thank you so much now im gonna try to get leak down test I changed pcv valve problem still there. anyone know a good site to purchase short block? Thanx
Old Mar 29, 2014 | 02:34 AM
myfirstzcar
How much oil is it going through?
Old Mar 29, 2014 | 04:07 PM
trisk12's Avatar
trisk12
Hi it depends on how much I drive the car I always have 2 litre of oil sometimes I finish it sometimes I don't. do you know if 2007 and up 350z engine will be compatible on 2003 350z?
Old Mar 29, 2014 | 04:59 PM
Spike100's Avatar
Spike100
You probably need a short block swap (and it should be a 350z engine) if you intend keeping the car. --Spike
Old Mar 29, 2014 | 05:51 PM
myfirstzcar
You need a vq35 DE block if that's the problem. I would invest some time into figuring it out first....short blocks ain't cheap!
Old Mar 29, 2014 | 07:14 PM
trisk12's Avatar
trisk12
Thanx for reply Im thinking of getting a used engine my car is manual transmission. Will there be a issue on swapping if I buy the engine and it came from auto transmission ?
Old Mar 30, 2014 | 03:07 AM
myfirstzcar
Shouldn't be an issue, but the junkyard will have an interchange manual to be sure.
I would still do the leakdown tests if I were you. If you could have one head pulled and fixed you'd be way better off than going through an entire engine swap with a used engine.
Old Mar 30, 2014 | 06:57 AM
trisk12's Avatar
trisk12
Yes ill get a leakdown test first thank you so much guys
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
