Engine turned off on stop light
Old Apr 28, 2014 | 03:15 PM
Carmeninchen's Avatar
Carmeninchen
Default Engine turned off on stop light
Hi there, my engine turned off when I was closing up on a stop light. As I tried to start it again, the started cranked, but the car wouldn't start for a couple minutes. As it finally started back up the "engine service soon" light came on. The same thing happened again a couple minutes later, and about 10 min later, the slip and the tcs off light came on as well. Has anyone had the problem before, or any idea waft it could be? Thank you for your help.
Old Apr 28, 2014 | 03:24 PM
350zchad's Avatar
350zchad
take it to get the computer scanned
Old Apr 28, 2014 | 03:40 PM
Carmeninchen
I was planning on doing that tomorrow.
Old Apr 28, 2014 | 03:41 PM
Carmeninchen
I just wanted to get an idea that I can bring appropriate tools if it is a quick fix.
Old Apr 28, 2014 | 05:16 PM
Spike100's Avatar
Spike100
You will be replacing the camshaft position sensors and probably the crankshaft position sensors.
When you pull codes for the offending components, it will probably be either the camshaft or crankshaft sensors, but not both. In fact you may be having issue with both.
Look at the code you pull, and then decide what you will replace.
--Spike
Old Apr 28, 2014 | 06:08 PM
350zchad's Avatar
350zchad
^^^there you go.. what a great forum
Old Apr 29, 2014 | 01:15 PM
florotory's Avatar
florotory
You can pull the code yourself if you don't want to wait. Odds are it's the cam pos sensor. Pretty easy fix
Old Apr 29, 2014 | 01:40 PM
Carmeninchen
It was the camshaft position sensor. Already replaced, super easy to do. thank you all )
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
Fixxxercask
Nov 9, 2015 11:10 AM
350z82
Oct 1, 2015 06:25 PM
samansharif
Sep 25, 2015 12:31 PM
