Airbag light keeps flashing?
Old May 1, 2014 | 02:15 PM
SoCali-Z's Avatar
SoCali-Z
Default Airbag light keeps flashing?
Hey guys,
My z's airbag light keeps on flashing. Any idea as to why and how to make it stop? I tried the reset procedure but think i didnt do it right.
Thanks
Old May 1, 2014 | 03:01 PM
KornerCarver's Avatar
KornerCarver
You may have a problem in either your seat belt or the air bag system. Here is what your owner's manual tells you about the flashing light..............
SUPPLEMENTAL AIR BAG
WARNING LIGHT
The supplemental air bag warning light, displaying
in the instrument panel, monitors the
circuits of the supplemental front air bag,
supplemental side air bag (if so equipped) and
curtain side-impact air bag (if so equipped)
systems, and pre-tensioner seat belt. The circuits
monitored by the air bag warning light are
the diagnosis sensor unit, satellite sensors, front
air bag modules, side air bag modules, curtain
side-impact air bag modules, pre-tensioner seat
belt and all related wiring.
After turning the ignition key to the ON position,
the supplemental air bag warning light illuminates.
will turn off after about 7 seconds if the system is
operational.
If any of the following conditions occur, the
supplemental front air bag, supplemental side air
bag (if so equipped) and curtain side-impact air
bag (if so equipped) systems, and pre-tensioner
seat belt need servicing:
I The supplemental air bag warning light remains
on after approximately 7 seconds.
flashes intermittently.
I The supplemental air bag warning light does
not come on at all.
Under these conditions, the supplemental front
air bags, supplemental side air bags, curtain
side-impact air bags and/or pre-tensioner seat
belt may not operate properly. They must be
checked and repaired. Take your vehicle to the
nearest NISSAN dealer.
WARNING
If the supplemental air bag warning
light is on, it could mean that the
side air bag, curtain side-impact air
bag systems and/or pre-tensioner seat
belt will not operate in an accident.
Repair and replacement procedure
The supplemental front air bags, supplemental
side air bags (if so equipped), curtain sideimpact
air bags (if so equipped) and pretensioner
seat belt are designed to inflate on a
one-time-only basis. As a reminder, unless it is
damaged, the supplemental air bag warning light
will remain illuminated after inflation has occurred.
Repair and replacement of these systems
should be done only by a NISSAN dealer.
When maintenance work is required on the
vehicle, the supplemental front air bags, side air
bags, curtain side-impact air bags, related parts
and pre-tensioner seat belt should be pointed
out to the person conducting the maintenance.
The ignition key should always be in the LOCK
position when working under the hood or inside
the vehicle.
Old May 1, 2014 | 09:04 PM
samsniss350z's Avatar
samsniss350z
^^^^^^^word for word.
Old May 2, 2014 | 02:02 PM
SoCali-Z's Avatar
SoCali-Z
ok thanks. I dont have the manual for the car so that helped.
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
