2003 350z overheat
So I never used a forum and I don't know where to post things but here we go.
I was driving in traffic after I had just put gas, I was going about 10-15 mph and would stop moderately do to the traffic. When all out of sudden I see a lot of smoke coming out of the hood, I look at the temperature gauge and it had sky rocketed to hot. I pulled over and turned off the car, poped the hood and looked around. I saw a small amount of radiator water on top of the radiator, not much but around 3 teaspoons. The hoses looked fine, the water tank was filled where it had to be,the fans would turn on when the car was only running, not just turning the key to the (on) position, I don't know if it should be like that or not I never noticed. So I let the car cool for about 15 minutes and gave it another start, again the car overheated and I turned it off. I then checked the water tank and it was dry, looked underneath the and saw a bit around the tank but i don't know if it was there before or after I had started the car the second time. I put a code scanner to it from autoparts and I got the code p1217, and also u1000. Please give me some help I'm so lost mechanically, and where I live the mechanics charge you and arm, a leg, and a eye. Also I did buy more radiator fluid and filled her up again.
Anyone
Anyone
Have you pressure tested your radiator cap? If it no longer seals properly, you will have regular leakage of radiator fluid and subsequent overheating. Whatever problem/solution you find, be sure to post here and let everybody else learn from your experience.
With radiator caps being so cheap, I'd go ahead and replace it and do a full coolant flush. You can buy "Leslie funnels" (I think) on amazon for around 20 bucks and it will help tremendously. If you have never done it before, there are some good how tp's on here. Anyway, if you get your coolant flushed correctly and it still overheats, check your thermostat out. I'm sure there is a how to for that as well
Well yesterday I didn't want to open up the radiator cap because I was scared it would pop off lol, so this morning I went and opened it (when it was cool) and there was no fluid in the radiator. But there was fluid in the coolant tank, I called a friend of mine who is a mechanic to come check it out, we'll see what it is. I'll post more feedback when he checks it out, I'm guessing water pump is gone bad :'( or maybe the system is clogged up....
Quick question, sense I guess the water isn't running to the radiator and it's dry, can I add coolant directly to it through the radiator cap? And then try running it to my mechanic, cuz otherwise I can't even drive a quarter mile without it overheating..
Yes. It is perfectly okay to put coolant or distilled water in your radiator through the hole that the radiator cap plugs.. Do it when the car is cold and open the bleeder screw at the back of the engine bay while filling.
Your description fits what happens when a radiator cap goes bad. Most of the fluid boils away as the radiator absorbs more and more heat and cannot transfer it effectively. Before you do anything else, just replace the radiator cap and refill the radiator. Once you get all the air bubbles out and the engine up to temp, do a visual inspection around the radiator to look for leaks.
So before I took it to the mechanic, he had told me to open the radiator cap and run the car and put coolant in (not through the coolant tank). So I did and then drove it about 7 miles, I put my hazard lights on and was going about 25-30 mph (in a 45 mph zone) and the car would over heat every half mile or so. I had to stop 3 times in total letting the car cool and then run it again. The odd part about that is after the 3rd time it wouldn't over heat and so I kept speeding till I got to 45 and the car was at normal temp for about 3.5 miles. Before I got to the mechanic I pushed the car up to 60mph and nothing, the car still didn't over heat. I know this is all long, but I appreciate the help and maybe it will help someone else out there too.
Thanks for the info, I'll try that tomorrow. The mechanic told me the radiator had good pressure, but I also mentioned to him that my car was leaking oil. Not a lot but very frequently a drop or 2 will fall on the catalytic converter, he mentioned to me that could do with the overheating and what not....i don't know if that's true or not???
The advise your mechanic gave you was a bit of a redneck way of burping the radiator and getting all the air out. There are radiator fill funnels like the Lisle that will do this same thing while idling in your garage:
But driving slowly like you did will dislodge most air bubbles as the Z comes up to temperature. Dollars to donuts, you put on a new radiator cap and the overheating issue gets resolved. Please post up whether this was the case.i
Justin100
Nov 29, 2015 03:58 PM
RWDBajan
Sep 8, 2015 06:25 AM
