stock bose radio not working
Old Jul 19, 2014 | 06:32 PM
Mvolps22's Avatar
Mvolps22
Default stock bose radio not working
I just bought an '08 350z and the Bose radio isn't working. It turns on, let's you adjust the volume and change the station but I don't get any sound. I took the radio out yesterday to look for anything obvious and when I was finished the radio worked perfect...one time. Shut the car off and back on and now I'm getting no sound again. Any ideas before I take it to a professional audio shop?
Old Jul 21, 2014 | 05:22 PM
oldschool350z's Avatar
oldschool350z
TThat's a very odd problem.. are you sure everything is right in the connector ( back of head unit)?
Old Jul 21, 2014 | 05:28 PM
travlee's Avatar
travlee
Master
check the amp back by the spare.... may or may not be the issue... sounds like you have a random short somewhere. get a cheap speaker and tap it into the wires coming directly off the radio before the amp, see if you get sound... do the same thing after the amp...
Old Jul 22, 2014 | 07:42 AM
Mvolps22's Avatar
Mvolps22
Does this change anything...I unplugged the battery for about an hour last night to try and "reboot" the headunit. After hooking everything back up the radio worked. It worked last night, and this morning but once I got to work and shut my car off I wanted to see if it would continue to work but unfortunately when I turned it back on, nothing again. Could a weak battery cause this issue? I doubt it but I'm grasping at straws. Lastly, i tried to get to the amp to check it but I couldn't figure out how to get the plastic piece removed that is on the left side of the spare. I took the spare tire out and all the carpet but I couldn't dislodge that last piece of plastic. Do i need to remove additional pieces first?
Thanks!
Old Jul 22, 2014 | 05:48 PM
Spike100's Avatar
Spike100
Question: If the H/U or car is tuned off for awhile, does it begin working again?
Old Jul 22, 2014 | 06:13 PM
oldschool350z
My issue was the head unit not powering on, and the cause was a blown fuse in the engine bay.
Old Jul 23, 2014 | 08:30 AM
Mvolps22's Avatar
Mvolps22
Seems that way, but it's not really consistent. After work yesterday I drove to target with no radio, when i came back out of target to drive home the radio worked again. Very unpredictable. The only thing so far that has been consistent is that if the radio doesn't work the first time I turn it on then turning the car off and on repeatedly doesn't seem to help.
Old Jul 23, 2014 | 08:36 AM
travlee's Avatar
travlee
Master
sounds like you have a short somewhere in the head unit
Old Jul 23, 2014 | 09:18 AM
Mvolps22's Avatar
Mvolps22
Possible to fix or does it need to be replaced?
Old Jul 23, 2014 | 09:19 AM
travlee's Avatar
travlee
Master
you could see if you can find an electronic repair place close to you... it is like 40-50 to diagnose it
Old Jul 23, 2014 | 04:17 PM
Spike100's Avatar
Spike100
Without actually testing the system, I can only guess.
I agree with travlee9374
It’s probably a short that is causing the Bose amps to go into safe mode (shut down). After things cool down, the amps begin working again. That’s a guess., but I cannot think of anything else that would be as random as you describe.
m_0g
Jun 3, 2021 10:05 AM
bcoffee20
Nov 19, 2015 06:39 PM
Sailors350Z
Sep 25, 2015 08:21 AM
Shane86
Sep 17, 2015 05:33 PM
issyz
Sep 10, 2015 02:00 PM
