How many filters does a stock Fuel pump have
Old Oct 3, 2014 | 02:14 PM
Manual35z's Avatar
Manual35z
Default How many filters does a stock Fuel pump have
Im a Automotive Technician and after some trouble shooting Iver determined that my injectors are clogging up with debre. Most likely from the fuel tank passing through the 1 sock filter on the bottom of the pump. Ive read that the stock pump has a sock and a micro filter but if it does mine is missing the micro filter. I need input from somebody that have taken apart there stock fuel pump as Im AM NOT going to replace a perfectly good fuel pump just for a filter
If i need a filter I will take my stock line and have it modified at a shop to connect to a metal in line filter unless somebody can suggest another method of adding a in line filter. Also if anybody could tell me what there fuel pressure is at idle that would be great. I know the specs are around 50psi at idle but mine is closer to 60psi.
Old Oct 3, 2014 | 08:31 PM
bealljk's Avatar
bealljk
Just the sock...
Old Oct 4, 2014 | 11:53 AM
FOOKhonda's Avatar
FOOKhonda
Pretty sure there are 1 or 2 inline filters as well. Not 100% on that though as it may have been an aftermarket thing, but pretty confident I read the stock z has some inline filters.. so you may have to worry about those too...
Someone should chime in and set it all straight though.
Old Oct 4, 2014 | 01:44 PM
mr. sparco's Avatar
mr. sparco
No.
Old Oct 4, 2014 | 02:02 PM
FOOKhonda's Avatar
FOOKhonda
Didn't think so. Can't remember where I read it at.. though it may have been someone saying they were adding them..
Old Oct 4, 2014 | 02:08 PM
bealljk's Avatar
bealljk
no inlines...
Old Oct 5, 2014 | 06:01 AM
Manual35z's Avatar
Manual35z
Okay just one sock on the pump just as mine has. Although when I took mine apart it was pretty dirty. Funny how Nissan seems to think that this one sock will keep all debre out. After cleaning my non serviceable(********) sock debre continued getting into the injectors shorty after. Problem is if there's a tear i didn't see nobody sells just the sock which puts me back at square one with out modifying the line.
Old Oct 5, 2014 | 06:31 AM
92K1500's Avatar
92K1500
I don't think I want you working on my car if you can't even install a fuel filter yourself.......
And yes, you only have the sock on the pump. No other filters. You're the first person I've heard of having a problem with it.
Old Oct 6, 2014 | 03:30 PM
Manual35z's Avatar
Manual35z
I wouldnt want to working on my car either. Your lucky if you can get a 50-60 psi line to hold fuel pressure with nothing but hose clamps. Do it right the first time or theres no point in doing it.
Well i guess im just thats lucky that some jack *** was messing with the pump before I got the car.
Old Oct 7, 2014 | 05:46 PM
bealljk's Avatar
bealljk
I'll sell you that sock if you want...it's an extra fuel pump assembly that I bought a little while back...PM me with a fair price.
Old Oct 7, 2014 | 06:18 PM
Manual35z's Avatar
Manual35z
thanks for the offer but im just going to go ahead and have the line custom made by a shop that does specialty hoses so i can just service the filter every now and then.
