HELP! 350z wont start!
Old Feb 26, 2015 | 05:30 AM
seanman33's Avatar
seanman33
Angry HELP! 350z wont start!
So let me get this out and everything i have tested.
First off, i started my 2005 350z and left to pick up some food. When i turned my car off to go inside to get it, everything worked fine. when i came back out to start the car, i turn the ignition, everything turns on, lights, horn, other accessories. When i go to start it, it just clicks once.
Ive tried, a new battery, ive tested that the starter is getting the full 12v. ive checked all the fuses, kick panel, behind battery, in front of battery. nothing looks like its bad. Is there any other thing i should check or fuses anywhere else?
I did notice that when i got my aftermarket head-unit installed it was done professionally at a store, so i dont think any of that wiring would cause an issue.
Are there any grounds i need to check somewhere?
Wet wires?
Please help.
My beautiful car is just sitting there and i cant do anything about it.
120k miles, replaced radiator, liquids. everything worked perfect.
i hear the full pump turn on so i know its not that.
PLEASE HELP!
The closest nissan dealership said that it was something with the steering lock box??
Last edited by seanman33; Feb 26, 2015 at 05:31 AM. Reason: nissan dealership info
Old Feb 26, 2015 | 06:20 AM
KornerCarver's Avatar
KornerCarver
It could be the Nissan Anti Theft System causing a problem. If so, you probably need to have the car towed to a dealer so they can sort out the problem.
Old Feb 26, 2015 | 06:35 AM
iideadeyeii's Avatar
iideadeyeii
If it just clicks once then usually means there is a bad connection on the battery terminals if the battery is fully charged like you said
Old Feb 26, 2015 | 06:42 AM
seanman33's Avatar
seanman33
thank you guys for the quick response, the + terminal does look a little corroded. I have tried using a jumper cable + on the terminal and then to the battery. is thatgonna work or no?
Old Feb 26, 2015 | 07:05 AM
i8acobra's Avatar
i8acobra
If it clicks once, it's probably the starter. If it makes no noise, that's something else and kinda difficult to diag without seeing the car.
Old Feb 26, 2015 | 11:51 AM
seanman33's Avatar
seanman33
how sure are you its the starter. i hear it click. its just not firing.
Old Feb 26, 2015 | 01:06 PM
kennyl5123's Avatar
kennyl5123
If you know where the starter at, give it a kick or lightly hammer it. It'll give you couple more times of use.
Old Feb 26, 2015 | 04:47 PM
350zchad's Avatar
350zchad
haha... I heard that before and gave a starter a whack and it started up..
Old Feb 26, 2015 | 06:55 PM
bith8791's Avatar
bith8791
A friend of mine had a Ford Ranger years and years ago, the starter began going out, he would have to crawl under the truck, hit it with a flashlight a few times and hurry up and crawl back out and start it up, he did this for a month or two before it finally gave out completely.
Old Feb 27, 2015 | 10:11 AM
monztr's Avatar
monztr
Old Feb 28, 2015 | 06:14 AM
dkmura's Avatar
dkmura
General & DIY Moderator
I'd agree with the other posts here: it's either a poor connection at the battery (full power not available) or a defective starter. Check the grounds carefully and the condition of the terminals. Let us know what it turned out to be...
lolwatbro
Oct 9, 2021 04:58 AM
Katie93
Sep 15, 2015 05:57 PM
RyansZ33
Sep 15, 2015 05:54 AM
Darkspy
Sep 7, 2015 09:09 PM
