clutch squeal when pressed.
Old Mar 7, 2015 | 06:08 AM
jzk91's Avatar
jzk91
Default clutch squeal when pressed.
i wasn't thinking strait and tried to show off, and ended up burning my clutch because i smell it. but the problem is when ever i press the clutch, it makes squeal sound, and i think clutch is not fully engaged when ever i am pressing the clutch. it only happens in low gears as well. Is it throwout bearing gone bad? and if i am going to replace throwout bearing and pilot bearing, would it be better off just changing whole clutch as well? or can i keep my clutch? it has 80k miles on it.
Old Mar 8, 2015 | 06:20 AM
SQuaLZ's Avatar
SQuaLZ
What did you do? You mean you were trying to show off?
What exactly happened?
My clutch pedal squeeks occasionally. Doesn't bother me though. I think all my cars at some point has squeeks from the clutch pedal.
Old Mar 8, 2015 | 07:01 AM
92K1500's Avatar
92K1500
Video would help. Your post is confusing.
Old Mar 8, 2015 | 10:30 AM
jzk91's Avatar
jzk91
It is coming from clutch disk. I was pressing both clutch and gas then let the clutch go to spin the car. Then after I hear the noise.
Old Mar 8, 2015 | 11:58 AM
Spike100's Avatar
Spike100
That's probably a slipping/worn pressure plate that no longer fully engages the transmission. If that is correct, you should feel "slipping" (along with the noise) when releasing the clutch.
Old Mar 8, 2015 | 12:06 PM
Neeko94's Avatar
Neeko94
The clutch tends to randomly squeak on alot of Zs. common.
Most cases its the clutch fork, pivot ball joint or the throwout bearing.
Old Mar 8, 2015 | 03:03 PM
jzk91's Avatar
jzk91
so i better off just buy a new clutch kit and install them then. right?
Old Mar 8, 2015 | 03:04 PM
jzk91's Avatar
jzk91
hope its not the folk since they are not in the kit;
Old Mar 9, 2015 | 09:46 AM
SQuaLZ's Avatar
SQuaLZ
You still never explained what happened. Maybe it would help diagnose the issue.
Old Mar 9, 2015 | 10:33 AM
jzk91's Avatar
jzk91
I wrote it down on one of comment. I pressed both clutch and gas and let the clutch off to spin the car... and then clutch pedal got stucked in. And after I pull the Paden back on it happens.
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
samansharif
Sep 25, 2015 12:31 PM
