Help. Dash cut off and Abs Slip and VDC light on
Old Mar 12, 2015 | 06:19 PM
DieselandZ's Avatar
DieselandZ
Default Help. Dash cut off and Abs Slip and VDC light on
I just put a new starter on today and when I went to do a test drive with it. My dash back lights cut off and center gauges and radio cut off. Then my ABS, VDC and Slip light popped on. Any ideas?
Old Mar 12, 2015 | 06:25 PM
Italianjoe1's Avatar
Italianjoe1
Sounds like something shorted out, did you leave anything loose near the wiring you moved to do the starter?
Old Mar 12, 2015 | 07:42 PM
DieselandZ's Avatar
DieselandZ
I don't believe so. I will check its weird cause everything cut back on when I tried it again then after driving for a minute or so it cut back off then the lights came back on. That happened twice.
Old Mar 12, 2015 | 08:21 PM
bealljk's Avatar
bealljk
have you installed a aftermarket radio? or have you messed with the HVAC controller wires?
Old Mar 12, 2015 | 08:32 PM
DieselandZ's Avatar
DieselandZ
It came with an aftermarket radio when I bought it. And I haven't messed with the hvac controller wires. It was fine until I changed the starter this afternoon.
Old Mar 13, 2015 | 11:02 AM
DieselandZ's Avatar
DieselandZ
Update. No AC no power anything except the windows. Check and replaced the fuse 6.
Old Mar 28, 2015 | 08:28 PM
DieselandZ's Avatar
DieselandZ
Update or if anyone has this problem in the future. It was a bad IPDM.
Old Mar 30, 2015 | 06:44 PM
Italianjoe1
So not related to the starter, just a bad coincidence? That sucks, at least you got it fixed.
Old Mar 31, 2015 | 06:35 PM
DieselandZ's Avatar
DieselandZ
Yeah or so I thought. I had it looked at by the dealership after fixing all codes. New cam sensor and crank position sensor. They ran there computer and said bad ipdm. That was replaced today and now it won't start again. I believe they said something about a fan. Any ideas?
loudtoyz
Apr 6, 2023 04:52 AM
AbrasiveRaysive
Sep 20, 2021 02:29 PM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
samansharif
Sep 25, 2015 12:31 PM
