350z no start
Old May 6, 2015 | 11:59 AM
greddyttz's Avatar
greddyttz
Default 350z no start
Getting no spark.
Car just died while driving one day under normal conditions.
I can hear fuel pump prime.
Replaced NATS antenna and ipdm already and still no spark.
I can still pull codes so I don't think the ecu is bad? "Code pulled doesn't pertain to no start. I am certain."
The car started a few times after it died but ran rough and died every time. Now it doesn't start at all.
If the fuel pulse/pressure isn't correct would it cause a no spark to plugs?
Old May 6, 2015 | 12:20 PM
travlee's Avatar
travlee
Master
what are the codes
Old May 6, 2015 | 12:54 PM
greddyttz's Avatar
greddyttz
I forget at the moment. I'll have to scan again when I get home and post it but I've talked to 3 performance shops as well as 2 dealerships before and they said it can't be that.
Has new cam/crank sensors too.
If I don't figure it out in the next 2 weeks I'm just going to bring it to the dealer.
Thinking it may be something with keys. I noticed not long before the red security light would stay on while driving sometime which is why originally I thought the NATS antenna finally went out but guess it wasn't that
Old May 6, 2015 | 12:56 PM
travlee's Avatar
travlee
Master
key might be shot
Old May 6, 2015 | 01:08 PM
greddyttz's Avatar
greddyttz
Only thing that throws me off is why the car would start a few times after and run rough and then not start at all?
Old May 6, 2015 | 04:28 PM
Spike100's Avatar
Spike100
Start by attempting to get the code(s). If that doesn't work, it is a much larger problem that requires guessing.
Old May 7, 2015 | 04:12 PM
greddyttz's Avatar
greddyttz
starting to think its a bad ground somewhere. motor has been R/I a few times....doubt its a tuning issue because its ran perfect for the past 3 years on the same tune. good battery connections/grounds. new ipdm,nats antenna/cam/crank sensors/spark plugs... guess i'll find out next week what it is when I bring it to the shop.
keys/ecu/bcm, bad ground, maybe even timing chain...lol idk but hope to find out soon!
Old May 7, 2015 | 04:23 PM
Spike100's Avatar
Spike100
^^ Get the codes. Then you know.
Old May 7, 2015 | 04:30 PM
travlee's Avatar
travlee
Master
and knowing is half the battle....... GI Joe!!!!!!!
Old May 7, 2015 | 04:36 PM
Spike100's Avatar
Spike100
For sure. And... Why do so many people resist (neglect?) getting codes that often provide definitive solutions?
Old May 7, 2015 | 04:38 PM
travlee's Avatar
travlee
Master
because noob. they would rather get on here and ask instead of being proactive they are being reactive
Old May 7, 2015 | 04:58 PM
Spike100's Avatar
Spike100
I do not want to discourage new members and their posts.
How can we help them find answers without insulting them when they ask routine questions?
Old May 7, 2015 | 05:10 PM
travlee's Avatar
travlee
Master
i get that, i do... can i be an ***, yep i can.
common sense would be to pull the codes, do just a bit of research, and then ask.... his first post was very vague at best and he still hasn't posted the codes.
Old May 7, 2015 | 06:04 PM
Spike100's Avatar
Spike100
I agree with you. It's strange that people do not pull codes.
lolwatbro
Oct 9, 2021 04:58 AM
Katie93
Sep 15, 2015 05:57 PM
RyansZ33
Sep 15, 2015 05:54 AM
Darkspy
Sep 7, 2015 09:09 PM
