350z back up light wont turn off? help please
Old Jun 30, 2015 | 08:37 AM
superrayo's Avatar
superrayo
Default 350z back up light wont turn off? help please
hi i have a 2003 350z, when i go on reverse my back up lights turn on but after switching to drive or neutral or parking my lights wont turn off again, i need to fix this so i can take it to inspection test, thanks
Old Jun 30, 2015 | 09:00 AM
jhc's Avatar
jhc
General & Tech Moderator
The easy fix, pull the bulbs for inspection.
I wouldn't mind, safer at night...Ck the switch on your shifter.
Old Jun 30, 2015 | 09:13 AM
travlee's Avatar
travlee
Master
https://my350z.com/forum/maintenance...wont-work.html
http://forums.nicoclub.com/my-revers...g-t440188.html
"That's definitely a strange one, not heard of that before. Most likely its just the switch in the transmission not "releasing" so to speak. If you get under the car you'll see what looks like sensors sticking out of the transmission. There should be 3 in all, the reverse switch, neutral switch, and speed sensor. I believe the reverse switch will be basically in the middle of the three and has a hexagonal body like a nut (as does the neutral switch). The speed sensor has a larger cylindrical body so it will be easy to tell between that one.
Just pull out the reverse switch and see if the switch is stuck. If so, you could try cleaning it to get it unstuck, otherwise if you can't get it to work I'd just replace it."
92K1500's Avatar
92K1500
Pulling the bulbs is far from easy on these cars....
I would go for the fuse instead.
Old Jun 30, 2015 | 09:24 AM
superrayo's Avatar
superrayo
ok guys thanks so much for your fast response, i will try removing the fuse or bulbs, great idea i hope it will pass and wont have to go under the car because that always scare me.
Old Jun 30, 2015 | 10:54 AM
pr_350z's Avatar
pr_350z
actually this happened to my previous 350z, there is a kind of "plug" on the brake pedal itself, this plug breaks off and causes that(when the brake pedal is not pressed the plug makes contact with a switch letting it know where it is positioned if I'm not mistaken), mine was replaced with a regular interior trim plug from the nearest gas station. The one from my clutch pedal broke too and that car would not start because of it.
Siqcology
Sep 18, 2019 01:45 PM
bcoffee20
Nov 19, 2015 06:39 PM
Vigman
Nov 17, 2015 04:34 AM
Katie93
Sep 15, 2015 05:57 PM
RyansZ33
Sep 15, 2015 05:54 AM
