Somebody pls help - auto trans not working properly
Old Oct 19, 2016 | 07:26 AM
11DJ11's Avatar
11DJ11
Default Somebody pls help - auto trans not working properly
I'm having issues with my 350z..Automatic Transmission. Sometimes it works sometimes it doesn't. Seems like it's slipping. I put it on drive and step on the pedal it only goes like 2 mph.. I switch it to reverse and I could feel the gears changing but it wouldn't move much..somebody Pls help
Old Oct 19, 2016 | 11:02 AM
Firebase99's Avatar
Firebase99
Sounds like the ball bearing socket is stripped.
Or a clutch plate, do autos have clutch plates?
Fluids maybe?
Old Oct 19, 2016 | 11:30 AM
icer5160's Avatar
icer5160
So many different things can cause issues with automatics, but it sounds like a problem with the torque converter or potentially a low fluid scenario.
I recommend taking it to a transmission specialist. Automatics are horribly complex, so much of the transmission's functions are controlled both by electrical components, but also the flow and pressure of the fluid. This could be purely a mechanical failure, but could also be an electrical issue.
-Icer
Old Oct 19, 2016 | 11:31 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Sorry- gotta provide more info than what you've posted to get some legit answers. Start with what year Z it is and how many miles. When did you purchase it and when did these tranny problems first occur? Were there any other factors that preceded these issues?
Old Oct 19, 2016 | 05:11 PM
travlee's Avatar
travlee
Master
guess taking it to a mechanic makes too much sense
Old Oct 19, 2016 | 05:20 PM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
It also doesn't register that theirs any fluid when uou checked ? Look for a leak up by the radiator.
Old Oct 21, 2016 | 09:19 AM
Arrtus's Avatar
Arrtus
Your tire pressure is probably low causing the g-force to throw off equilibrium in your Z's pendulum when trying to accelerate. I suggest changing your tires.
Old Oct 21, 2016 | 12:28 PM
absurdparadox's Avatar
absurdparadox
What has happened to these forums?
Old Oct 22, 2016 | 06:13 AM
dkmura's Avatar
dkmura
https://my350z.com/forum/maintenance...e-section.html
broom n mop
Jan 21, 2016 03:44 PM
carfi179
Southern California
913
Apr 2, 2008 03:21 PM
jvolpe
Nov 24, 2002 07:36 PM
