Oil leak HELP!?
Old Mar 21, 2018 | 03:11 PM
JASON1995's Avatar
JASON1995
Default Oil leak HELP!?
So I have a oil leak and it seems to be leaking somewhere on the driver side, that’s where all the mess underneath the car is at. What could it be?
New 350z owner.
Old Mar 21, 2018 | 08:00 PM
Bak3rme's Avatar
Bak3rme
check valve covers, camshaft sensors. spray down the oil mess with brake cleaner and then u get a fresh look at where the leak is coming from exactly.
Old Mar 21, 2018 | 08:01 PM
JASON1995's Avatar
JASON1995
Okay I’ll do that. Appreciate it.
Old Mar 23, 2018 | 02:18 PM
HOMiEZ's Avatar
HOMiEZ
some more info will help us help you. if you can't describe it take it to a mechanic.
Old Mar 24, 2018 | 10:19 PM
Skinzy98's Avatar
Skinzy98
Have you done an oil change recently? If so make sure the oil cooler gasket is on correctly. Had no clue how to replace one and I blew through tons of oil and gaskets till I figured out the gasket goes around the small ring and not the large one lol
zKid350z
Dec 12, 2016 10:26 AM
joeyvq27
Oct 13, 2016 01:59 PM
AgentReaver
Apr 29, 2016 02:11 PM
BRICKS Z
May 5, 2003 08:41 AM
