No start, electrical issue
Old Mar 22, 2018 | 10:57 AM
mx5_leo's Avatar
mx5_leo
Default No start, electrical issue
Really weird problem, 03 350z. Ecu is not powering on. I have power and ground at all the main pins except pin 111 which goes to the relay. There’s power at the fuse but nothing at the relay but I have continuity from relay to ecu. The radiator fans come on full blast, fuel pump doesn’t turn on, and service engine light doesn’t come on. The NATS light on my dash is solid, which leads me to believe it’s an NATS issue, but when I plug my scanner in it cannot connect to the vehicle but it does power up.
PLS HELP
Old Mar 22, 2018 | 04:35 PM
mx5_leo's Avatar
mx5_leo
Here are the codes my car came up with (I got from a friend at Nissan)
Old Mar 23, 2018 | 08:57 AM
zakmartin's Avatar
zakmartin
If it's not an ECM fuse, it's most likely a blown ECM.
EDIT:
Why are you creating a new thread on this? If you want to continue the discussion from your original thread, then you should just stick with that one. You'll just waste everyone's time and get a lot of the same info otherwise.
https://my350z.com/forum/maintenance...-ecu-nats.html
Old Mar 26, 2018 | 03:50 AM
mx5_leo's Avatar
mx5_leo
When the old ecu fried it also melted the wire that wire that goes from the ecm to relay. Got the new ecm in and is running good so far
cferraro85
Aug 15, 2013 04:53 AM
skn5002
Jul 30, 2011 06:28 AM
bijan z
Jul 8, 2009 07:59 PM
