Starting Issue
Old Apr 26, 2018 | 05:00 AM
carie's Avatar
carie
Default Starting Issue
I have been having this problem with my Z for a while now. It crank but wouldn’t start, sometimes takes 5 or 6 tries before its start. This don’t happen every time, but lately is happening more often, almost every day now . I took it to the mechanic but they couldn’t figure out what’s wrong. There’s a code P1084, but they said is not related to my issue. Any ideas?
2005, 35th Anniversary edition, 69,900 miles, brand new battery
Old Apr 26, 2018 | 06:51 AM
travlee's Avatar
travlee
Master
my bet is camshaft and or crankshaft sensors....
Old Apr 26, 2018 | 07:33 AM
jhc's Avatar
jhc
General & Tech Moderator
Simple things 1st-
How old is the air filter?
Has the car been sitting with old gas?
Have you done any work on it prior to the problem?
Old Apr 26, 2018 | 08:43 AM
carie's Avatar
carie
Originally Posted by jhc
Simple things 1st-
Air filter is around 4 months old. I use the car often, but I had it sitting for a while (around 2 months) at the end of last year
Old Apr 26, 2018 | 08:45 AM
carie's Avatar
carie
But, should I be getting codes for these sensors? The only code I’m getting is a 1084.
Old Apr 26, 2018 | 09:00 AM
travlee's Avatar
travlee
Master
Known many of people that never got codes but sensors were bad. If you replace, get oem sensors.....trust me
Old Apr 27, 2018 | 06:16 AM
Cracka350's Avatar
Cracka350
I had a similar issue that happened overnight. It ran fine and the next morning I had to crank it for several seconds before it started. It turned out to be the crankshaft position sensor. Replacement available at your auto parts store.
New one on the left. Old on the right.
Old Apr 27, 2018 | 09:39 AM
carie's Avatar
carie
Thanks! I getting a different codes thought, P1084 and P1615
Old Apr 27, 2018 | 01:58 PM
jhc's Avatar
jhc
Bank 2 cam pos sensor. (Driver side)
NATS immobilizer problem.
https://www.google.com/search?ei=U5z...8ObN3Pe3mwM%3D
heyitzalex
Dec 4, 2022 12:50 PM
tougeracing
Jan 11, 2011 01:07 PM
Chef-J
Mar 25, 2008 05:08 PM
Ruthless18x
Oct 2, 2007 10:08 PM
