Lack of accelaration, misfires after spark plug change.
Old May 16, 2018 | 12:04 PM
josh2288l's Avatar
josh2288l
Default Lack of accelaration, misfires after spark plug change.
Hi guys,
I recently changed the spark plugs of my 2005 350z. Nothing was wrong with them or the car, I was replacing the valve cover gasket and decided to replace the spark plugs while there.
Upon starup,I am experiencing lack of acceleration, misfires. I ended up putting the old spark plugs back but the problem remains.
Scanned the car: got a misfire error from cylinder 6. I replaced the coil from cylinder 6, issue remains.
can anybody suggest what else to look for?
Thank you!
Old May 16, 2018 | 06:02 PM
Spike100's Avatar
Spike100
I would be suspicious of the possibility that something happened when you replaced the valve cover gasket. I wonder if you don’t have a vacuum leak somewhere; but, without seeing the car, I am only guessing
Originally Posted by josh2288l
Hi guys,
Thank you!
Old May 17, 2018 | 08:43 AM
vegasanthony's Avatar
vegasanthony
Some people get the wires crossed on driver side bank for Pistons 4 and 6. I've try switching those
I actually marked mine with white marker
and if you disconnected the throttle body you have to do a TB relearn
Old May 21, 2018 | 04:51 AM
josh2288l's Avatar
josh2288l
The wires were crossed from pistons 2 and 4. That resolved the issue.
Thanks for your help.
Pickle Rick
Dec 19, 2017 08:22 AM
dudegetalife
Feb 25, 2016 03:21 PM
mcarther101
Sep 23, 2013 05:34 AM
Reign_Man
Apr 17, 2010 08:17 PM
Zmego1985
Apr 16, 2006 07:33 AM
