engine oil and spark plugs
Old May 31, 2018 | 05:13 AM
Slambo's Avatar
Slambo
Default engine oil and spark plugs
My 05' 350z conv. mt has been sitting for about a year. Im going to perform maintance, which fluids and new sparks plugs should I use?
Old May 31, 2018 | 05:28 AM
bealljk's Avatar
bealljk
Ive always liked the NGK brand but there are other such as bosch or OEM Nissan ... unless you doing something crazy with the car you standard OEM / OEM replacement will be fine.
Old May 31, 2018 | 06:00 AM
dkmura's Avatar
dkmura
General & DIY Moderator
OEM spark plugs are NGK, but ND will also do fine. Still--and depending on mileage--there's no real need to replace the plugs unless they're damaged or worn out. As for oil, there's plenty of threads on recommendations, but I'd go for Mobil 1 0-40W FS Euro blend and a top quality filter.
Old May 31, 2018 | 06:14 AM
Slambo's Avatar
Slambo
The Car has been sitting for about a year so I was going to do as much as I could while its in the shop at this time. am I reading this correctly 0-40w oil? fulsyn euro blend?
Old May 31, 2018 | 07:14 AM
iideadeyeii's Avatar
iideadeyeii
The shop should know. . .
Old May 31, 2018 | 07:27 AM
SpartaEvolution's Avatar
SpartaEvolution
Agree on both counts - I just replaced mine with NGK Iridium IX (LFR5AIX-11 #4469), and I use the M1 0-40 with k&n filters.
Old May 31, 2018 | 08:41 AM
zakmartin's Avatar
zakmartin
If you didn't add a fuel stabilizer before storing the car, then dump the fuel and fill it with some fresh gas. You might want to add a bottle of Techron to the tank, since without stabilizer, it's likely to be a bit on the varnish side at this point. Also, check the condition of your hoses and belt. It wouldn't be a bad time to lube the hinges and do a quick inspection of your boots as well.
LowZ33
May 8, 2020 03:45 PM
anotheraznguy
Nov 14, 2017 06:26 AM
RobPhoboS
Feb 13, 2017 09:25 AM
No Payne
Jan 9, 2017 05:18 PM
craig12895
Misc.
21
Nov 27, 2016 04:37 AM
