How to torque axle bolts? Help
Old Jun 11, 2018 | 02:36 AM
Bernardo Z33's Avatar
Bernardo Z33
Default How to torque axle bolts? Help
Hello everyone I'm changing the wheel bearing on my car but I just don't know how in the world to fit a torque wrench back there and torque the hub bolts or the bolts that connect the axle to the diff or brake caliper bolts. How did you guys fit a torque wrench back there?
Old Jun 11, 2018 | 05:09 AM
dkmura's Avatar
dkmura
General & DIY Moderator
It can be done- you need to be creative in how you angle a 1/2" torque wrench in underneath and work in small increments until you achieve the desired torque. I did it on jackstands, but a lift would have helped immensely.
Old Jun 11, 2018 | 05:25 AM
LexD's Avatar
LexD
Not cheap, but the flex-head, split-beam torque wrenches are worth their weight in gold for accessing those hard to reach fasteners.
Old Jun 11, 2018 | 05:31 AM
Heel Til I Die's Avatar
Heel Til I Die
A little hard to explain in words, but here goes...
For the axle-to-diff bolts, I used a thin wall socket for my torque wrench. To stop the axle from spinning while tightening the bolts, I fit a combination wrench onto one of the other bolts and "wedged" it to a secure point under the car at an angle.
It is a little tedious since you have to rotate the axle and move the combination wrench to the next bolt each time you tighten it, but it gets the job done.
I imagine you can wedge the same combination wrench onto one of the axle-diff bolts and then torque all the hub bolts after that since it would prevent it from spinning.
sickZ31/Z33
Dec 2, 2014 11:04 PM
koren
May 4, 2011 08:37 AM
dscheers
May 15, 2006 12:15 PM
Moodie
Northern California
Nov 14, 2003 10:17 AM
