What can cause the tachometer needle to drop after letting off the gas?
Old Jul 11, 2019 | 04:54 PM
MisfireZ's Avatar
MisfireZ
Default What can cause the tachometer needle to drop after letting off the gas?
Hi yall, so i have a 2003 350z that's been running great until recently its been having a misfire i think? When i turn it on when the engine is cold it sounds great and the idle is fine. But when the engine heats up to normal operating temperature and i'm driving it, it starts having a misfire. When it gets into second gear, the engine will do a low hum and you can feel the power disappear and won't accelerate no matter how much you press on the accelerator until you fully step on it. When the engine hums and i let off the gas, it will jolt a bit and hum loudly while the rpm needle very slowly goes down until it gets to 1k and plummets before jumping back up to regular idle speed. At 2k RPM i let off the gas and the needle while plummet down to 900 rpm and then jump back up to regular idle speed. Any ideas what it could be? Here's a video before it got even worse recently
Old Jul 11, 2019 | 06:41 PM
Giovamike27's Avatar
Giovamike27
https://www.youtube.com/watch?v=vhsqhFtgi8I
I know what your problem is... youre letting off the gas pedal
Old Jul 11, 2019 | 06:49 PM
MisfireZ's Avatar
MisfireZ
Can't step on the gas without risk of the engine blowing up
CS350Z86
Mar 21, 2010 09:02 AM
DieselOne
Jul 12, 2009 01:51 PM
leg killa
Nov 30, 2008 04:11 PM
itsjiggajames
Nov 4, 2008 05:47 PM
robcassell
Jan 2, 2006 09:11 PM
