Oil leak ?
Old Jan 21, 2020 | 10:41 AM
Jose Blat's Avatar
Jose Blat
Default Oil leak ?
So i made the worst decision of my life 4 days ago by bringing my Z to a shop to get my oil changed , went to a local firestone because i could not change my oil at the time.
Whatever i get the oil change done and next day i do a small pull and i have smoke coming from my engine bay 🤦🏽‍♂️.
I pullover open my hood and lots of smoke coming from what looks like somewhere by my intake and where my dipstick is.
At first i thought it was because the oil pan drain bolt was loose but i got that tightened and still smoking at high speeds. I cant figure out what it is , not even firestone can even tell me where its coming from ..
Told me they didnt know where the oil is leaking from.
Anyone have any idea or know what or where it could be ?? im out here stressin lol
Looks like oil cant tell
Smoke from where its circled
Old Apr 9, 2024 | 09:30 PM
vqbori's Avatar
vqbori
Default oil leak on driver side
Bro i’m having the same exact issue i’m smoking bad when i get up to a higher speed and when i come to a red light i thought it was my valve covers so i replaced them thinking it would’ve been solved but it’s still doing it bad i noticed oil on my compressor but have no idea where it’s leaking from, did you ever figure out what it was?
Old Apr 10, 2024 | 09:10 AM
iideadeyeii's Avatar
iideadeyeii
Is the oil fill cap screwed on?
Old Apr 10, 2024 | 09:12 AM
vqbori's Avatar
vqbori
yes I have a brand new oil cap with the aluminum valve covers i got from concept z
Old Apr 11, 2024 | 04:43 AM
Heel Til I Die's Avatar
Heel Til I Die
Is the dipstick seated correctly?
Old Apr 11, 2024 | 04:46 AM
Bak3rme's Avatar
Bak3rme
Check the O ring for the dipstick tube. should be near the bottom.
See here:
https://www.z1motorsports.com/cylind...ng-p-6771.html
EDIT: OP has DE not HR, dismiss the comment.
Old Apr 11, 2024 | 02:39 PM
icer5160's Avatar
icer5160
The dipstick is not fully seated! That thing is sitting a few inches to high. Common issue! Make sure the seal for the dipstick is intact, if it's not, you will need to purchase a new one, I don't think the rubber plug seal is replaceable on these.
-Icer
zKid350z
Dec 12, 2016 10:26 AM
joeyvq27
Oct 13, 2016 01:59 PM
AgentReaver
Apr 29, 2016 02:11 PM
BRICKS Z
May 5, 2003 08:41 AM
