HELP! 350z problem
Old Mar 11, 2020 | 05:47 PM
tyler.350z's Avatar
tyler.350z
Default HELP! 350z problem
Hello, i've tried figuring this out and i can't. going to be taking it to the shop soon but would like your input on if and how you fixed this problem if you've ever experienced it.
So i had my lower ball joints changed by a shop and ever since then i get a Tire rub type sound mixed with a popping sound everytime i turn left. It doesn't start until about 10mph and the popping/rubbing noise gets faster or slower depending on speed. i've checked everything from tie rod ends to brake pads to see if those were loose. My brake pads were just changed. i do need new rotors but my brake pads are not loose against them. my wheel bearings are all good and so are my tie rod ends. the only thing that needs replaced in the future is my upper ball joints. BUT the popping/rubbing noise changes with speed so it wouldn't make sense that the ball joints would be making that noise. Any insight??
Old Mar 11, 2020 | 08:04 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Rubbing or popping sounds usually leave a signs of scrapped metal or rubber on suspension, wheels or tires. Have you jacked up the car and carefully inspected all these parts? This problem could have many causes, and only careful inspection will reveal its source.
Old Mar 11, 2020 | 08:13 PM
tyler.350z's Avatar
tyler.350z
yes, theres no rub on any of the tires or rims. or any suspension component. It also gets faster or slower depending on my speed
Old Mar 11, 2020 | 09:17 PM
rustyschopshop's Avatar
rustyschopshop
have you double checked torque on lug nuts?
Old Mar 12, 2020 | 02:33 AM
travlee's Avatar
travlee
Master
what year is the car?
Old Mar 12, 2020 | 11:10 AM
tyler.350z's Avatar
tyler.350z
Yes I’ve checked the torque and it’s an 03 enthusiast
toykilla
Mar 17, 2019 09:13 PM
riteonjon
Sep 4, 2011 11:01 AM
Rekinyze
Jan 15, 2010 04:59 AM
gmueip
Jul 28, 2008 01:08 PM
