Stalling/ and loud hissing, squealing noise
Old Mar 18, 2022 | 01:05 PM
highley.z33's Avatar
highley.z33
Default Stalling/ and loud hissing, squealing noise
I have an 03 350z 93,000. Mods are Kinetix Velocity Manifold, z1 m-spec CAI (street version), and invidia n1 exhaust.
a month or so after installation of the Kinetix Velocity Manifold, I was driving, somewhere around 4k rpm, put it in neutral, and the car stalled. Ever since, anytime i get it high in the rpm range, and put it in neutral it stalls. This has been happening around a year and a half. Now the weird part is, the idle is normal, it doesn't bounce fluctuate at all. (i have not gotten a tune yet).
On top of this, recently in the past 6 months a new problem occurred, with a loud hissing/ squealing, on cold start, and it lasts until the car is well warm enough. once it's warm i gave it a rev and it came back, but as the car kept getting warmer, and i kept giving little revs, the noise would be less and less, until it isnt there anymore.
and now even more recently within the past couple weeks, i raced a buddy in 2nd gear, and when i punched it, it felt like the car heisitated or sputtered, and then all the power kicked in.
I hope this is enough, if anyone can give me real solutions, I would greatly appreciate it.
Old Mar 18, 2022 | 05:37 PM
Ponyryd's Avatar
Ponyryd
Kinda sounds like a vacuum leak, can you pinpoint the area? If so, try spraying some carb cleaner/brakeclean/WD-40 at the suspect area and listen for a change.
Old Mar 20, 2022 | 07:08 AM
jhc's Avatar
jhc
General & Tech Moderator
Not sure how you can be remotely surprised the engine doesn't run correctly with those mods and no retune.
As stated above, you might try putting a vacuum guage on it but in my experience vacuum leaks cause idle surge.
The noise you're hearing is most likely your intake manifold gasket whistling as air rushes past/over it. Remove it, seal both sides and reinstall to correct torque
(45-60 INCH lbs.) Gl!
No Payne
Sep 12, 2017 04:40 PM
asteroidgalaxy
Nov 4, 2016 12:53 PM
seZy350
Apr 13, 2008 07:48 PM
Valond
Apr 26, 2005 08:09 PM
lemonjihwan
Jan 30, 2004 03:05 PM
