HELP!! Car wont start!
Old Aug 12, 2022 | 12:09 PM
paullliius's Avatar
paullliius
Default HELP!! Car wont start!
I have an 03 350z 6MT, the other day i got in the car and tried to go to work and it didnt start, the car didnt even crank nothing. I got the battery checked even though i purchased it at the beginning of summer it ended up being good, next i thought maybe it was the clutch pedal sensor so i bridged the connector and still nothing. Then i went over every single fuse i could find on the car and they were all good. next i went to check the relays and even went to a local 350z parts guy which i managed to purchase a whole IPDM. I swapped over the relays and still nothing, so then i switched over the whole IPDM and nothing. Starter was my next guess so i managed to get the car started by pushing it and dumping the clutch in gear which allowed me to get it to my driveway. Which is where i finally i got some spark. i took a wire connected it to the battery and ran it straight to the starter and the car cranked not problem. So only thing i could come up with was that the starter was not receiving power somewhere and now im lost and ready to give up.
Old Aug 14, 2022 | 04:11 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Welcome- at least you know the starter is intact and functioning. Have you tried checking and cleaning the battery connections? A buildup of corrosion to the ground cable should also be eliminated.
betzyraa
Jul 26, 2021 12:43 PM
Z33Gio
Jul 9, 2020 11:49 AM
StraitZangsta
May 22, 2018 02:52 PM
tomsyl325
Oct 28, 2014 04:13 PM
chestuhr
Sep 30, 2013 05:54 PM
