Routine Oil Changes not at a dealer?
Old Feb 26, 2004 | 07:07 PM
BriA5's Avatar
BriA5
Default Routine Oil Changes not at a dealer?
My local dealers are horrendous, and if I can avoid them I will do anything I can to do so.
What's everyone's opinions on doing routine oil changes on the Z at oil change "specialists " such as Jiffy-Lube, etc.?
Old Feb 26, 2004 | 08:41 PM
alindo's Avatar
alindo
I just got my oil change at Performance Nissan for $21.95 for regular oil. 30 minutes or less or else its free. Good thing mine took 40 minutes
Old Feb 26, 2004 | 09:29 PM
yobri's Avatar
yobri
Change the oil yourself. Oil changers like Jiffy Lube are hit and miss at best. Meaning that in a lot of cases, the 'kids' are just careless while other instances you get a 'decent' oil change.
I've heard and read about horror stories at 'specialty' oil changers. If I HAD TO get an oil change by someone other than myself, I'd do it at the dealer.
NzZ's Avatar
NzZ
Default Re: Routine Oil Changes not at a dealer?
Don't use these guys. they have screwed up many of my cars...although dealers have done the same. Still, I think their employees are poorly trained (if trained at all), and they often don't replace washers and filters.
NzZ
Old Feb 26, 2004 | 09:43 PM
yobri's Avatar
yobri
Default Re: Re: Routine Oil Changes not at a dealer?
Yikes! Washers I can understand, but not changing the filter...?
Old Feb 27, 2004 | 06:12 AM
mode101's Avatar
mode101
I agree... Change the oil yourself. It is very easy to do, and will save you money.
All you need is some rhino ramps from autozone. While your there, also pick up a filter remover, these nissan filters are so freekin small, the typical filter wrench is too big. These are a couple of dollars.
You can get a 5 qt jug of Mobil 1 5-30 synthetic oil from Walmart for like $18.88. And you can get your oil filters, and washers from here:
http://www.courtesyparts.com/Merchan...e=15208-VQ35DE
Good luck
Old Feb 28, 2004 | 08:22 PM
n8vz's Avatar
n8vz
How do you guys get your Z up Rhino Ramp? my Z is not lowered and i can't clear my set of Rhino Ramps that i bought 8 years ago. Did they change the angle of incline?
Old Feb 29, 2004 | 01:44 AM
yobri's Avatar
yobri
Don't know the incline of past Rhino Ramps, but current ones have no problems for clearance. Measure your current ones and then go to the auto shop to see if there's a difference. The ramps are SO MUCH easier than having to jack up the car and place jack stands.
Old Feb 29, 2004 | 05:53 PM
Z_Coaster's Avatar
Z_Coaster
as Yobri mentioned, these oil changing specialists are hit and miss and not worth the risk. the last time I had my oil changed, it was at a Jiffy lube and it was a nightmare. I watched them as they worked and I just cringed. They started my engine without the oil filter on it and, as you can imagine, oil got everywhere. For a couple of weeks after the change, I went back there a few times due to oil leaking from somewhere. I still don't know if the leak was actually a leak or if it was left over oil spewed from not having the filter on. I'm also missing some screws that hold up the plastic "skid" plate/cover (not sure what you call it). A couple of days after repeated visits to Jiffy lube, I stood back from the car and noticed this cover hanging down and dragging on the road. Besides this, the grease monkeys left oil residue all over the interior along with scuffing my door panels with their filthy boots.
I normally do my own oil changes, but the Z was way too low to get under, but since this experience with Jiffy, I've picked up a set of Rhino ramps and have no problem rolling onto them to replace the missing screws.
BTW, if you want to pick up a set, don't buy them online. I did a search online for a set and found the cheapest for somewhere around $40 (if I remember right). Went to my local Sears and found them for $20/set.
Old Mar 4, 2004 | 02:25 PM
Lokix's Avatar
Lokix
kinda OT but a ? about the rhino ramps? Could you use these and back the car up on them to do the exhaust? just a thought.
Old Mar 4, 2004 | 02:47 PM
yobri's Avatar
yobri
Don't know about using ramps to install an exhaust (seems like it would work) but you'll more than likely scrape up the front bumper and undercarriage if you were to lift the back without doing the same for the front. The front bumper seats rather low on this car.
Old Mar 4, 2004 | 05:14 PM
Ultimateone's Avatar
Ultimateone
Yup I installed my old Tanabe exhaust with just ramps
Old Apr 9, 2004 | 01:48 PM
350zluvr's Avatar
350zluvr
wouldn't it be possible to get two sets of rhino ramps (4) and just drive up on those to raise the entire car (front and rear simoultaneausly)?
Old Apr 9, 2004 | 04:55 PM
yobri's Avatar
yobri
The Z is too low for the ramps to fit under for the rear (if you are doing the driving up for the fronts). You can only back up on to them to get the rears, but then you'll miss out on the fronts. Either-or situation... more easily done with 4x4's that have sufficient rise
Old Apr 9, 2004 | 05:26 PM
aws6000's Avatar
aws6000
I have a set of rhino ramps (brand new) and my Z just barely clears the ramps. Too close for my comfort, so I place a 2x6 in fron the ramps, which seems to help out the clearance just a bit. Not the perfect solution though. If I had to do it again I'd get a nice racing jack and jack stands.
Old Apr 10, 2004 | 10:18 PM
s9am_me's Avatar
s9am_me
yeah i'm thinking about doing it myself. dealer charged me $40 last time. I was just lazy at the time. gonna get some rhino ramps when i get the chance.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
ablaine
Nov 29, 2016 10:13 AM
