Clutch Gone :(
Old Oct 30, 2024 | 07:27 AM
komputer's Avatar
komputer
Default Clutch Gone :(
I am a little bit upset, clutch has gone @ ~120k KM. I called around to some shops to get some quotes to get it replaced and oh my god the prices...
I've read on here a bunch that it should cost maybe $1,000 - $1,500 USD, everywhere is about $600 USD for labor. One shop quoted me $1,250 CAD ($897 USD) for the Clutch kit, then another $2,000 CAD ($1,436 USD) for the flywheel. A Nissan dealer quoted me the same for the clutch kit and $1,800 CAD ($1,292 USD) for the flywheel. All for OEM parts - all in all it comes out to about $4-5K CAD ($2,800 - $3,600 USD).
Now, I'm not sure how bad inflation has gotten, considering a lot of the posts about price of parts are from 10-15 years ago, but I still think that's way too much.
I am looking into some aftermarket parts like the JWT Clutch Kit + Flywheel, which only runs about $800-$1,200 USD depending on where you get it.
Any suggestions on other clutch kits I should look into?
Old Oct 30, 2024 | 08:34 AM
lifekenophobic's Avatar
lifekenophobic
I have the JWT clutch/flywheel combo and overall recommend it. It's noisy and honestly sounds terrible at lower RPM's, but it holds decent power and seems to be a great option for the price. ConceptZPerformance seems to be running a sale on them right now making the price even more appealing.
Old Oct 30, 2024 | 08:59 AM
komputer's Avatar
komputer
Do you daily drive your Z? I daily drive mine and I was wondering if that clutch gets annoying at all?
I've heard a lot about the sound, I personally don't mind because I got a kickass sub system and aftermarket speakers to drown out the noise lol
Old Oct 30, 2024 | 09:47 AM
lifekenophobic
I don't daily my Z, but would have no trouble doing so with this clutch kit. It's only slightly stiffer than stock.
Old Oct 30, 2024 | 10:13 AM
icer5160's Avatar
icer5160
Those prices are reflective of OEM parts. The OEM dual mass flywheel is very expensive and ultimately not worth the cost since they wear out over time and cannot be re-surfaced. If you don't want to deal with gearbox chatter noises at low RPM, then stay away from lightweight flywheels. Go for an aftermarket clutch and flywheel kit, and lean towards a heavier flywheel to keep the chatter/noise down. Engagement/feel of the clutch pedal will feel the same or better.
There's plenty of threads on here covering options, I recommend doing some research/reading before making a purchase, but expect about $900 for a decent clutch/flywheel combo that can hold up to 450ft/lb of torque. Labor rates change depending on location and shop. $600 for a clutch job sounds cheap to me.
Good Luck!
-Icer
Old Oct 30, 2024 | 10:19 AM
komputer's Avatar
komputer
Good Luck!
-Icer
Labor prices weren't an issue for me haha, about 5 hours of work and my shop usually cuts me a deal with how often I'm in there lol. Didn't know that the OEM flywheel couldn't be resurfaced, one shop quoted me $200 for remachining it and $2,000 if it cannot be remachined.
I think I wouldn't mind that chatter (race car makes race car noises or something like that) will probably go with the JWT. I've checked out some of the threads here and it looks like JWT is definitely the most popular and enjoyed so I'll probably go with that after consulting with a shop :^)
Old Oct 30, 2024 | 12:27 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
As mentioned, clutch noise is a function (partly) of flywheel weight. Heavy = quieter. OE dual mass flywheel is double damped, heavy (~30lbs), and dead quiet.
Many don't care and opt for a lightweight unit for the performance. Not me, personally hate light flywheels. Swapped an OE setup (kid car) for the JWT clutch but with the 26lb iron flywheel option. Great choice. A tad noisier than stock but nearly imperceptible. Great feel and none of the rev drop nonsense I disdain.
Check it out here:
https://conceptzperformance.com/jim-...sd_p_18529.php
Daily driven.
Old Oct 30, 2024 | 01:36 PM
komputer's Avatar
komputer
Check it out here:
Daily driven.
I quite like that price, very affordable. I think I'll opt for the lighter flywheel, though, I was planning on upgrading my clutch & flywheel in the future so this is a perfect excuse to get this done :^)
Also, clutch failed on me like an hour ago. Was driving and was like "this thing is not making it very far". 7 neutrals and counting... Broke down right when I got near my house hahaha
Old Oct 30, 2024 | 06:30 PM
icer5160's Avatar
icer5160
That's a stupid good price. Go full race car mode if that's what you want, it's a personal preference at the end of the day. But there is a learning curve associated with moving to a lightweight flywheel. Mic hinted at this earlier, less rotational mass means the vehicle will be less forgiving when getting into gear and revs will drop faster which can make smooth shifting a bit harder.
What do you mean by "7 neutrals and counting" ? Is it popping out of gear on you? Or is the clutch just slipping that bad?
Cheers!
-Icer
Old Oct 30, 2024 | 06:33 PM
komputer's Avatar
komputer
Cheers!
-Icer
I think I will definitely go full race car mode lol, it's just financially more responsible and it was the original plan!
And 7 neutrals as in the car don't move no more... Lost power to all gears completely, friend said he thinks I blew the tranny, which is possible. Won't know for a bit.
Old Oct 31, 2024 | 10:08 AM
iideadeyeii's Avatar
iideadeyeii
I run a $200 ebay aluminium flywheel and a $90 ebay clutch.
Stage 1 Clutchmaxx on ebay uses the same oem clutch disk. The part numbers are identical.
I could only recommend getting a quality TOB because the bearing does make quite a bit of noise from the ebay kit.
juju
Oct 5, 2012 07:24 PM
odoyelrules
North Central
Jul 31, 2012 06:43 PM
capnvivi
Apr 21, 2012 06:13 AM
chillah7889
Dec 17, 2011 11:04 PM
Hardon1
Nov 30, 2006 04:02 PM
