Problems with gas guage / filling tank completely.
Old May 10, 2004 | 09:24 AM
  #41
a_p's Avatar
a_p
Default Re: Re: Fuel Tank gauge doesn't fill
I did some research and found the following:
http://puckparches.proboards4.com/in...num=1079789588
The user Infinitiexpert found that on G35s, the fuel tank has "two fuel sender units, some times is necessary to ohm test the units to find the bad one" Another user had a problem with his 2004 350z only filling to 3/4 of a tank
Even more interesting was a TSB that I found on the 2003 Infiniti GX series:
http://www.infinitihelp.com/Ownershi.../ITB03-073.htm
Basically it says that there are two sending units that need to be reinstalled
And if those two weren't interesting enough, I called 1800NISSAN1 and spoke to a representative. He said that he has not heard of this fuel tank problem in the 350zs, but if I were to take my car into a Nissan service center, they would fix the "fuel sensor" in the gas tank. They will fix the problem for free if the car is less than 3 yrs/36000mi.
Jeff, those were the good old days, where I would visit this website twice a day, hoping to find out the horsepower, torque and 0-60 on my preordered Z.
Anil
Originally posted by Scafremon
Good to hear from you too a_p! This month is the 2 year anniversary of those pics, and why I decided to throw up the old-school 'Vin Soup' avatar. Those were some fun times back then, going to GroupZ meetings to hear/see what was going on with our cars.
As for fuel issue, it sounds like we share same issue. No pop-charger here either (or any perfomance mods for that matter). I also don't think flipping the nossle over will do anything but make me create a mess. I really think the tank is full, and it is just the gauges not reflecting it.
I haven't taken it into (or spoken with) Nissan yet, but plan on doing so very soon. I'm tempted to go ahead and drive like 100 miles past E, just to prove that there is more fuel in the tank...but, seems like a trip to the dealer is more appropriate.
Old May 12, 2004 | 04:46 PM
  #42
MonkeyBoy's Avatar
MonkeyBoy
Anybody else try the Redline SI-1? I want to see if it is an isolated case (me). I filled up again recently ... 12.4 gallons and the guage went beyond the Full mark again.
You can get it at Pepboys for 5.99 a bottle.
Old May 13, 2004 | 07:31 PM
  #43
a_p's Avatar
a_p
Has anyone taken in their car to have the fuel gauge fixed yet? Huntington Beach Nissan said they'ld fix my gauge if I make it over there during business hours with a nearly empty tank.
Old May 13, 2004 | 08:31 PM
  #44
Scafremon's Avatar
Scafremon
How will you determine nearly empty?
I might take mine there too, since I work in Westminster.
Old May 14, 2004 | 04:51 AM
  #45
joebva's Avatar
joebva
This morning, for the 5th time, my Z shuts off the fuel pump after only putting in ~5 gallons. I took it into the dealer a month ago and of course they could not reproduce the cutoff. They ordered one of the sensors that goes in the tank. I am taking it back in next week.
After reading another post I tried turning the pump handle upside down after the pump shuts off...and it works. Once I get a couple of more gallons in the tank I can then flip the handle back to the normal position and continue filling.
If you look at the fuel tank in the service manual it has a hump, which creates 2 areas for fuel. One side is much smaller than the other. This may be the "reserve" that someone mentioned in an earlier post and this may cause the car not to fill up.
I would try flipping the pump handle 180 degrees and see if another few gallons go in.
Old May 14, 2004 | 05:26 PM
  #46
a_p's Avatar
a_p
I reset my trip odometer after every fill up... I average around 20mpg. So if I'm averaging crappy gas mileage (19mpg) x 18 gallons used = 342 miles. So I should be safe at 300miles.
If you take your car to HB nissan, ask for Jeff. He knows about the fuel gauge problem
Old May 15, 2004 | 07:53 PM
  #47
conquestcar's Avatar
conquestcar
Same problem here.
Seem like the gas tank gauge float/sensor is the problem. Could affect how the miles per gal is calculated?
Old Jun 10, 2004 | 09:33 PM
  #48
a_p's Avatar
a_p
I just put in a bottle of Redline SI-1.. it's only 6 bucks, and it can't hurt. I'll run through this tank and keep you posted.
Old Jun 11, 2004 | 10:08 AM
  #49
BOZ23's Avatar
BOZ23
Correct me if I'm wrong, but I think I read in the Owner's Manual that the Z's fuel tank has a small reserve. This might be causing all of the fill-up problems. I'll double check.
Old Jun 11, 2004 | 03:39 PM
  #50
MonkeyBoy's Avatar
MonkeyBoy
Actually you are right about this. The DTE and gas guage generally like to read empty when 16 gallons of fuel have been used. There is a four gallon reserve. I mentioned the Redline stuff for the gas guage problem. Orignally, when I would fill the tank up till vapor cut off (and then some) the gas guage upon starting the car would read about an 1/8 of a tank below Full. When I first drove the car, the guage would read well about the full mark. After a tank of Redline, the guage starting acting normal again; when I filled the tank up, it would go above the full mark. Since doing this (whenever I posted in this thread that I would), I have not had a problem since.
Old Jun 12, 2004 | 10:31 PM
  #51
CornyRacing's Avatar
CornyRacing
Just finished the fill-up tonight. And yup! Tank goes well past the Full mark. How bout some more people try it out? I am pretty sure that the Redline SI-1 is only around $5. If anyone is willing to post their results, let us know!
I pre-ordered my Z and have had it for 21 months and this problem started about two or three months ago. Man i thought i was the only one with this prob. Ill try that redline stuff and see if it works. Thanx for the tip MonkeyBoy! Ill keep u posted.
Old Jun 16, 2004 | 12:14 PM
  #52
a_p's Avatar
a_p
Default Redline S-1
If you read my posts over the last month or two, my 2003 Z has also had the problem where my fuel gauge would report an empty tank after driving 200 miles. Even after fill up, it would only fill to 3/4 of a tank per the gauge reading.
Although my dealer was willing to replace one of the fuel tank sensors, I decided to take MonkeyBoy's advice and tried Redline S-1 after a fill up....
As silly as this may sound, I was able drive my car 350 miles before the empty light came on, and after I filled up my empty tank, my gauge went back up to Full.
Amazingly it worked. I was quite amazed that only after 20k miles that my gas tank would be dirty, especially since I only use Chevron premium (with techron).
I'm sold. I'm planning to use Redline S-1 every 5-10k miles just to keep my fuel system clean.
thanks monkeyboy!
Old Jun 16, 2004 | 03:28 PM
  #53
MonkeyBoy's Avatar
MonkeyBoy
Your welcome! What I find amazing is how I just happened to come across this by chance ...
Old Jun 16, 2004 | 05:15 PM
  #54
Scafremon's Avatar
Scafremon
You guys have sold me on trying the Redline SI-1. WIll buy some tomorrow and advise if my results are also positive.
Interesting that I have also been using Chevron Premium with Techron since day 1 on my car......
Old Jun 17, 2004 | 10:53 AM
  #55
MonkeyBoy's Avatar
MonkeyBoy
Cool
Hopefully this will make it a trifecta ... then we can petition the mods to make this a sticky or something.
Old Jun 18, 2004 | 09:05 PM
  #56
a_p's Avatar
a_p
Default anyone else try redline s-1 yet?
Old Jun 24, 2004 | 09:36 AM
  #57
samlc's Avatar
samlc
My dealer (Boardwalk Nissan in Redwood City, CA) replaced my gauge set/cluster as a means of fixing this problem last week. I fueled up last night. 16.3 gallons and the needle was just below the full hashmark. What a surprise, my dealer left something unfixed again!
Anyway, if your dealer recommends fixing the problem by replacing the gauges, tell them it probably won't work (but probably will create new rattles).
I will go buy some Redline S-1 later and post my results.
I can't wait to switch jobs so I can sell my car.
-s
Old Jun 24, 2004 | 06:01 PM
  #58
klimekp's Avatar
klimekp
Odd, my dealer replaced the fuel level sensor which didnt work, then they replaced the cluster and now the fuel gauge works again.
Old Jun 28, 2004 | 05:44 AM
  #59
Scafremon's Avatar
Scafremon
Redline SI-1 did not seem to work for me, at least after (1) tank of gas. I filled up this morning. Gauge was close to if not sitting on "E", DTE display indicated 60 miles to empty. I figured I should be able to get 15 gallons in.
Was only able to pump in 13.5, and gas gauge needle stayed short of "F".
I just reviewed my initial post in this thread, and at that time I was only able to get 11.5 gallons in when my DTE say 51, so, maybe things did improve some.
Hmmm....well, I don't think it is worth having a dealer replace my gauge cluster. I'll post an update in about a week after my second fill-up.
Old Jul 8, 2004 | 04:59 PM
  #60
samlc's Avatar
samlc
Ditto the last post. The Redline fuel system cleaner did not work for me either. Filled up today and the needle was just shy of the F hashmark (again). The car drives better though...
Anyway, sh*tcan the Redline and make yet another appointment to see those friendly, lovely folks at your Nissan dealer. (can you smell the sarcasm?).
-s
