Need an Oil Filter recommendation.
Old May 2, 2004 | 04:53 PM
alienx's Avatar
alienx
Default Need an Oil Filter recommendation.
All I can find locally anymore is purolater, whcih I don't want to use. Can anyone recommend a decent filter and where to get it on-line? It doesn't have to be K&N or Mobil One, but I'll take any suggestions I can get.
Thanks!
Old May 2, 2004 | 07:12 PM
lowrider's Avatar
lowrider
K&N model HP-1006. A little larger than the recommended HP-1008, but with the same pressure specs. I've used them for close to a year now. IMO, the best oil filter out there. Buy from http://www.truckpartseast.com/ @ $8.97 ea. with no shipping.
Lou
Old May 2, 2004 | 10:22 PM
MonkeyBoy's Avatar
MonkeyBoy
You can also get the Mobil 1 m1-110 or m1-105 which work well also. Not sure if Autozone is out in New Jersey, since I am such a sheltered fairweather monkey, but you can get them there.
Old May 3, 2004 | 10:18 AM
alienx's Avatar
alienx
Thanks!
After looking around the web with both of your suggestions, it looks liek the easiest and cheapest solution is to go over to AAP or Autozone and have them get me a couple of the K&N's.
Thanks again.
Old May 3, 2004 | 10:47 AM
lowrider's Avatar
lowrider
Good Choice on the K&N. Don't forget make it the HP-1006.
Lou
Old May 3, 2004 | 11:04 AM
bixby's Avatar
bixby
Actually, you should stick with OEM filters. If you buy them in bulk (6 or more) the dealer should discount them for you. I've never used anything but OEM on my cars and as you can see in my sig, the Z31 just keeps on going.
Old May 3, 2004 | 04:02 PM
lowrider's Avatar
lowrider
bixby
Nope - Go to this thread, scroll down to find out why you should not use the stock filter.
https://my350z.com/forum/showthread....threadid=73063
Lou
Old May 4, 2004 | 08:31 AM
bixby's Avatar
bixby
Originally posted by lowrider
bixby
Lou
Thanks lowrider! Good to know. I wonder if the OEM's I use on my other Z's will fit. Regardless, If not I think I'll have to go with the Maxima OEM.
Old May 4, 2004 | 11:03 AM
mydogscool's Avatar
mydogscool
Default best oil filter
http://www.wixfilters.com/
buy on line at http://www.citylineauto.com/
cost 5.50 for a Maxima filter
Cost 6.50 for a Z filter
Go figure
I use the one for the matching year Maxima.
Ben using them for over 10 years. None better.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
