at what milage do you replace diff fluid
Old May 11, 2004 | 06:04 AM
n8vz's Avatar
n8vz
Default at what milage do you replace diff fluid
I am approaching 15,000 miles for my Z.
When do you guys recommend changing differntial fluid?
I was going to bleed the brake and change the tranny fluid at the 15,000 mile service. How about the differntial?
Old May 11, 2004 | 11:57 AM
MonkeyBoy's Avatar
MonkeyBoy
It couldn't hurt. I changed mine after breakin at 1200 and again at 30k.
Old May 11, 2004 | 12:41 PM
HanZolo's Avatar
HanZolo
MonkeyBoy, are there any gaskets to replace on the drain/fill plugs?
Old May 11, 2004 | 01:26 PM
MonkeyBoy's Avatar
MonkeyBoy
I just reused mine. I am sure you can get them from Nissan though. I usually have my car up on a lift once every other week for tweaking things, and I have not noticed any problems so far.
Old May 11, 2004 | 09:54 PM
maximumsportZ's Avatar
maximumsportZ
What fluid did u use? and weight?
Old May 12, 2004 | 02:44 PM
MonkeyBoy's Avatar
MonkeyBoy
I used Redline MTL which is an 75W80 fluid GL-4 rated.
Old May 16, 2004 | 06:35 PM
corsair's Avatar
corsair
I replaced mine at 10,000 miles with Amsoil. Felt like I was driving with 2 clicks on the ebrake before the fluid swap. There were also a LOT of metal shavings in the oil and stuck to the plug!
Old May 17, 2004 | 12:47 PM
MonkeyBoy's Avatar
MonkeyBoy
Oops ... check that, I used the 75W90 fluid which is Gl-5 in the diff. Sorry about that.
lapham3
Oct 7, 2022 03:15 PM
burglapfd
Dec 6, 2020 01:04 PM
Rev_Night
Nov 7, 2020 06:00 PM
