Rear Hatch Opening Fix
Old Jun 27, 2009 | 08:49 AM
  #141
zeruck's Avatar
zeruck
Originally Posted by Eddie@Performance
We have them for $23.04 for the newest revised model. Part# 84415-CD71A
Great price, Performance Nissan definitely has our best interests in mind.
Quakerroatmeal, a good dealer will match price. Show local dealer the appropriate post with revised part#. I bet some would sell you the old part.
Old Jun 27, 2009 | 09:36 AM
  #142
quakerroatmeal's Avatar
quakerroatmeal
What's the difference between old part vs the revised version? What was revised?
Old Jun 29, 2009 | 07:52 AM
  #143
Eddie@Performance's Avatar
Eddie@Performance
Performance Nissan
The revised one supposedly has stiffer springs in it, i cant confirm for sure as i dont have any of the old versions to compare with. The changes could be very minimal or you could find that Nissan prepacks those with pennies already lol not sure.
Old Jun 29, 2009 | 11:17 AM
  #144
LehighGuy's Avatar
LehighGuy
Well my warranty covers my hatch opening problem, and good things too! The Nissan stealership quoted it at $580. That's already 1/3 the cost of my warranty in just fixing some stupid hatch issue. Wow.
Old Jun 29, 2009 | 12:21 PM
  #145
quakerroatmeal
580$...LOL..and 580$ for what? Are they changing out your entire hatch and struts? That's hilarious.
Old Jul 16, 2009 | 05:02 PM
  #146
agentZ's Avatar
agentZ
thanks for the DIY guide, works great!
Old Jul 17, 2009 | 12:36 AM
  #147
quakerroatmeal
Anybody else have a problem when changing out the spring lifts to brand new ones still having the problem of having to click the hatch multiple times still? Just changed mines out to new ones and still a problem.
Old Aug 30, 2010 | 07:16 PM
  #148
PGooT Z's Avatar
PGooT Z
idk whats wrong with mine, but i got new heavy duty struts from ebay from seller invotekken, (it works great!) and tried putting 2 pennies on each side, did NOT work, tried 3, didnt work, i even super sized it to 5 pennies on each side (it was a pain in the a** putting the rubber housing back on tho)... still have to hit the button once, then lift it a little bit then hit the button again... its pissing me off.
i have a nismo v1 spoiler installed.
any suggestion would really help thanks!
Old Sep 9, 2010 | 08:22 PM
  #149
CsabaH's Avatar
CsabaH
Thanks for this tip. I've owned the car for two years and just wrote off the problem as just a quirk! I some how stumbled upon this thread today and performed the $.04 trick. Problem Solved!
Old Sep 23, 2010 | 07:46 AM
  #150
BashaZ's Avatar
BashaZ
Wow, I have had this stupid problem ever since I bought my Z, I kind of just dealt with it thinking that there wasn't a solution....by chance i stumbled acros this thread!
I decided to use 3 pennies each side, just because I figured it would pop higher than 2 pennies, and man it works great, I don't have to use 2 hands to open my trunk anymore (one pushing the button, one ready under the hatch to lift it and soon as I push the button)
Hopefully, the extra thickness does not leave a dent.....only time will tell!
But it WORKS GREAT! THANKS MAN!
Old Sep 25, 2010 | 03:08 PM
  #151
infinite's Avatar
infinite
most efficient fix i've seen and it sure works too
Old Oct 5, 2010 | 05:44 PM
  #152
stealthrapt0r's Avatar
stealthrapt0r
worked great, thanks!
Old Oct 5, 2010 | 05:58 PM
  #153
JasonZ-YA's Avatar
JasonZ-YA
i hate this issue...
-J
Old Jan 12, 2011 | 10:36 AM
  #154
RDR350Z's Avatar
RDR350Z
I too have a Nismo spoiler and it makes the hatch extra heavy. About a year ago I was smacked in the face by the hatch falling shut and it split my nose open right across the bridge between my two eyes...The dealer took care of it the next morning after seeing the gash and bruising by replacing both struts and the spring lifters -- apparently they installed the newer version of the spring lifters...now a year later the hatch is doing it again!
What I've done to improve my situation is:
-Installed heavy duty hatch struts, they work even when it's in the 20s (cold for Texas)
-Replaced the spring lifts
-Added ~4 pennies to each NEW lift
-Lowered the hatch latch mechanism (http://www.*********.com/forums/141-...attle-fix.html)
I believe the newer version of the spring lifters has a shortened metal shaft, when the spring is fully compressed I do not see the shaft extend past the base where it mounts to the hatch. What this means is if you add more than 2 pennies I cannot see how the shaft could possibly extend enough to hit the outside panel as noted by a few posters as the shaft doesn't extend past the base...
-RDR
Old Nov 19, 2011 | 01:09 PM
  #155
JMII's Avatar
JMII
Easy fix! Thanks for info and picts. Pressing the release button twice every time i wanted the hatch open was unacceptable.
Old Jan 12, 2012 | 11:15 AM
  #156
kz0's Avatar
kz0
So you mean it should actually be popping open. I just got my 03 and all it does is crack it and in cold weather it doen't go up. Anyone have a fix for that?
Old Feb 2, 2012 | 02:49 PM
  #157
JRed350z's Avatar
JRed350z
stumbled across this and its a great easy fix! went with the 3 pennies on each side for now, but might switch to 2 if its gonna put a dent in
Old Feb 2, 2012 | 02:53 PM
  #158
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Yeah don't push it, I got the dent in one side. It's small but I know it's there.
Old Jul 18, 2012 | 04:24 PM
  #159
bmyles's Avatar
bmyles
Just did this fix 5 min ago. Worked like a charm. I might look into the new springs just because if they're not too much. Big thumbs up!
Old Nov 28, 2012 | 01:01 PM
  #160
petem-z's Avatar
petem-z
amazing. I can't believe that worked. Such a simple and cheap fix to a nagging problem. Thanks!!
